GT-H Hood
The Analog Admin!
Received 2,992 Likes
i know this hood isnt functional but is it possible to just leave the small vents that it has open and it will become functional? or is their any way to put something to extract air through that hole?
Response from Shelby Automobiles...
I emailed Shelby Automotive some time back and one of my questions had to do with the hood and their response to me should answer your question about making it functional. Here is what they replied:
3) The hood is shipped with the heat extractor non-functional. It can be made functional. Cutting the top opening is simple but the underneath will require much work to look right. Also the production hood grill we sell turned out to be not functional. It’s not required so you could make your own if you wanted a grille. I haven’t attempted to see how much work it would be to drill out and trim the “holes†in ours to make it functional or if it would still be presentable.
4) The hood is fiberglass. The dimensions are the same as the stock hood naturally except taller. The only numbers I have are the throttle body on a GT has 7/8-1†clearance from the bottom with the liner installed and one hood I weighed at 54 lbs.
tc
Originally Posted by relayagent
i dont see windshield washer nozzles, how do you deal with that? do the production gt-h from hertz have them?
Here is a little bit better pic of the false opening.
http://i58.photobucket.com/albums/g2...2/100_0754.jpg
Real Cowl Induction Hood!
I am building a real Cowl induction hood .. I got the Air Intake already built.. I am just waiting for the 5" COWL to arrive so I can take the hood to the shop to get the COWL molded in and painted Windveil Blue..
http://img285.imageshack.us/img285/5...ech21883ph.jpg
The GT-H hood is sweet but it wont solve the problems of engine bay heat.. If you want to do that, you must build or buy a real cowl induction hood!![Bling](https://themustangsource.com/forums/images/smilies/bling.gif)
http://img420.imageshack.us/my.php?i...ech21900qm.jpg
![Question](https://themustangsource.com/forums/images/icons/icon5.gif)
I like clean lines on my hood. I like the Shelby GT500 hood with the exception of those scoops. I am thinking about adding the Shelby GT500 front fascia, GT-H hood and CDC rear spoiler combo.
