Third Brake Light Problem
Old Nov 2, 2009 | 11:27 PM
y2kcbr's Avatar
Hello all,
So my third brake light (High-Mount) is out and I can't seem to locate my manual for where the Third brake light fuse is. Popped off cover and nothing 'jumps' out at me :/
Any help would be greatly appreciated.
2008 CT/CS. Thanks!
EDIT: To add, I looked at my service manual...still can't locate the third-brake light fuse :/
http://www.motorcraftservice.com/pub.../08musog3e.pdf
Old Nov 3, 2009 | 07:10 AM
watchdevil's Avatar
Originally Posted by y2kcbr
Hello all,
2008 CT/CS. Thanks!
It's probably not on a fuse by itself seperate from the taillamps. Did you check the obvious to see if the bulb burned out? Check the bulb connector for 12v when the pedal is depressed, and check for a bad contact or socket overheating. Check also to make sure the wiring from the deck lid has a good ground. After that then I would look at the brake light switch where there is likely a seperate circuit coming off it going to that light only. Don't forget it may also be controlled by the Smart Junction Box in the right lower kick panel.
Old Nov 3, 2009 | 10:35 AM
y2kcbr's Avatar
I'll check those out tonight. Thanks for the reply. I'll post my findings after I get done.
Old Nov 3, 2009 | 08:04 PM
frank s's Avatar
The only failure on the 2006 convertible i had was the third brakelamp bulb. Little hair element in there was hanging loose. New bulb set me back a lot more than I expected, but it was worth it.
Old Nov 3, 2009 | 09:17 PM
ford4v429's Avatar
legacy Tms Member
the center light on my 06 and the wifes 07 have never worked that I know of...the 09 does, but its got 3 miles on it. anyway, must be one cheap bulb...Ive followed dozens of S197s over the last few years, only saw 2 with a working center brakelight...personally think it looks better without it, but might get you a ticket too...knock on wood, not yet for me
Old Nov 4, 2009 | 11:55 PM
GONE_N_60's Avatar
My Third Brake Light went out a few weeks after I got my car (bought it used with just over 10k miles) and it was covered under warranty.
Old Nov 5, 2009 | 07:43 AM
rony1976's Avatar
Are you serious? you went to the dealer because a light going out??!?! Funny
Old Nov 5, 2009 | 07:57 AM
05GT-O.C.D.'s Avatar
I lust for a M24
I put the CDC DT on and haven't seen that thing since.
Old Nov 5, 2009 | 08:05 AM
MusicMan66's Avatar
As long as it's under warranty, absolutely. Make them pay for it. The labor's the easy part.
Old Nov 5, 2009 | 11:49 AM
y2kcbr's Avatar
I scheduled an appointment with Napa Ford. I have also had an ongoing issue with the Tire Pressure Sensor (and Monitor) fault. Ford never fixes it as they can't duplicate the error.
Anyways, going in to get this looked at on Friday. Thanks for the replies.
I agree, if it's under warranty, I'll take it in for anything, even a lightbulb!
Old Nov 5, 2009 | 11:37 PM
GONE_N_60's Avatar
It was there for an oil change and I let them know that It needed to be replaced
Old Nov 6, 2009 | 12:52 PM
y2kcbr's Avatar
Wrap Up:
Ford Service Dept: "We are sorry however we were unable to see the brake light being inoperable. It works fine. The only thing that we (we = more than one technician) can think of is when you installed the "Mustang" sticker over your Third brake light it may have made the light go out."
WTF, are you serious? El oh El. I almost cried in the dealership when I heard him say that.
On my other error with the Tire Pressure Sensor...
Ford Service Dept.: "We are sorry, we are going to have to charge labor to look at this because it is not covered under your manufacturers' warranty nor your dealer warranty."
Me: "Fair enough, I'll just remove the sensor and receiver and will that null my warranty?"
Ford Service Dept.: (after a few minutes of banging away on the PC there...) "Yes. It will."
My kicking and screaming fell on deaf ears...I'll remove it next time I rotate tires.
Old Nov 6, 2009 | 12:53 PM
I lust for a M24
??? so does the light work or not?
Old Nov 6, 2009 | 01:19 PM
y2kcbr's Avatar
It works. Must have been the sticker!
Old Nov 6, 2009 | 01:21 PM
I lust for a M24
Jim74656
May 1, 2023 02:15 AM
JonsMustang
Aug 10, 2015 05:03 PM
Michael Follett
Jul 24, 2015 06:58 AM
Will3212
Jul 16, 2015 10:30 AM
Kev006
Jul 8, 2015 05:29 AM
