Shelby 4.6 liter Fuel Rails
Old May 8, 2011 | 05:51 PM
  #61
MSVR3's Avatar
Thanks a lot, my wife is always laughing at me cause on weekends I'm in garage with my 11yr old son cleaning everything.
Fuel gauge is Auto Meter.
Old Jun 27, 2011 | 06:45 AM
  #62
SeanD's Avatar
Does it have a special fitting on it? Do you have a part number handy for it by chance?
Sean
Old Jun 27, 2011 | 10:12 AM
  #63
Scruffy281's Avatar
What kind of hose connection is that on the intercooler coolant tank?
Old Jul 23, 2011 | 03:33 PM
  #64
SeanD's Avatar
How did you guys use the 3/8" spring lock tool on the fuel line to get it off? Mine does not seem to want to get in the opening properly because there is a part of the frame in the way.
This is the spring lock set I have:
http://www.princessauto.com/workshop...nnect-tool-set
Is this the same thing to use on the bottom coupler. The fuel rail side was eay as there is nothing in the way, but that bottom one just doesn't want to budge.
Sean
Old Jul 23, 2011 | 07:42 PM
  #65
Scott2's Avatar
Sean
Sean, I have the Princess Auto set as well, worked fine at the fuel rail end but would not work at the frame rail. I ended up buying a 3/8" aluminum tool, I believe also from Princess Auto. With a little struggling and the aluminum tool I was able to release the OEM line at the frame rail.
Scott
Old Jul 23, 2011 | 09:33 PM
  #66
SeanD's Avatar
Hey Scott,
Are they these ones?
http://www.princessauto.com/workshop...disconnect-set
If so, I will go get it in the morning.
Thanks,
Sean
Old Jul 23, 2011 | 09:49 PM
  #67
Scott2's Avatar
Hey Scott,
Thanks,
Sean
Sean, yes, the gold one is the 3/8". Good Luck!
Sxott
CoyotePremium13
Oct 7, 2015 07:17 PM
Ray11
Sep 25, 2015 12:43 PM
