Lowering my GTCS, advise
It's time to lower my 'stang. I like the looks of dropping 1.5" I'd like suggestions as to which is the best kit for the money. I'm also guessing that regardless which kit I go with, a four wheel alignment needs to be done. Thaks in advance.
I'd say check here https://themustangsource.com/showthread.php?t=447906 , and then do some research. Don't think about it too much though cuz there's so many options your head will start spinning. I've been planning this also and kind of like some of the options from BMR http://www.bmrfabrication.com/2005Mustang.htm
I just got new tires for it and had always had problem with the front ones being worn on the inside as if I had a problem with negative camber. The stealer told me it was normal for the s197s. I'm wondering if it came out of the factory with a bit of negative camber.
I've got an '07 with the GT/CS front and rear bumpers. I lowered mine with the Steeda Ultralites, and bought an adjustable panhard bar at the same time. The drop wasn't drastic enough to need a new alignment, though. It rides great, retained the stock ride comfort and added a little more for sporty driving. I am still on the stock struts/shocks too, although I might someday swap them out for the FRPP units, or maybe the Tokico D-specs.
Which one to choose: Ford Racing M-5300-P or the Steeda Ultralite? Start with that and then later move to better shocks, swaybar etc. The FRPPs drop 1" and the Ultralites 1.5". Hmmm!
I have a 07 and love the look of my CS I had the Eibach Pro-kit with the Tokico D-Specs installed and have it set to the softest setting and love the ride it feels better then stock. Here is what it looks like.
Swamp Donkey Aficionado
Wow, talk about a lot of information. To be honest, I like the ride of my 'stang since it's not a street racer or will ever be on the track. I just don't like the 4x4 look, just like everyone else. I thought if would be as simple as swapping out springs such as the steeda's ultralites and an alignment. Anyone else enjoying their ride with just a spring swap? Or is it not worth it unless the struts and other components are also swapped?
Another way to approach the fender gap would be larger diameter tires. The standard tire/wheel combinations come out at about 27.2 inches diameter; I see Tire Rack lists some Pirellis for 22-inch wheels that are 28 and 30 inches diameter. Half the diameter dimension-change would be at the top, reducing the gap by a half to an inch and a half without lowering springs. Get the gear ratio back by changing the differential gears.
Well boys, I think I'm going to wait to collect more funds to do it right. I just want to drop it for looks but don't want to end up with a bad ride. I actually like the way the ride feels right now and would like to maintain that feel. From what I understand, just using lower springs is not the way to do it. Would everyone agree that if dropping with springs, at a minimum the use of proper struts/shocks is a must?
