FRPP Front HUB Install with ARP Log Studs
Old Feb 2, 2012 | 11:52 AM
Scott2's Avatar
I plan on running Race Star wheels in the future so I am upgrading to FRPP Hubs with ARP long studs and I will be adding ARP long studs in the rear next. The ARP studs are 1 inch longer than the OEM studs.
Before picture OEM Hub and Studs:
Baer Caliper and Rotor removed and Spindle nut backed off with a 35mm socket and breaker bar:
OEM Hub removed:
FRPP Hub installed and torqued to 221 lbs-ft with a 36mm socket, and dust cap installed:
Baer Rotor and Caliper installed:
Wheel installed with FRPP Open Ended Lug Nuts (for use with the SVT wheels, I have McGard Open Ended Lug Nuts for the Race Stars):
Pretty simple install, the aspect that took the longest was probably removing the Red Loctite from the Caliper Bolts.
Old Feb 3, 2012 | 05:11 PM
ricksGT/CS's Avatar
" WOW ",,looks cool ,great job .
Old Feb 3, 2012 | 07:01 PM
Scott2's Avatar
Thanks Rick. I installed the passenger's side rear studs after dinner tonight. Will get out to the garage hopefully this weekend to finish the driver's side. Pics to follow.
DarrenGT
Aug 21, 2015 07:07 PM
Mackitude
Aug 17, 2015 04:14 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
