Steeda 05-13 GT/GT500 Triple Pass Heat Exchanger w/Fans
Old Nov 6, 2012 | 01:14 PM
SteedaBrandon's Avatar
Former Vendor
Thumbs up Steeda 05-13 GT/GT500 Triple Pass Heat Exchanger w/Fans
Check out our new triple pass heat exchanger with fans for the 2005+ GT and GT500! Let me know if I can help you with anything.
Steeda Triple Pass Heat Exchanger With Fans - $749.95
When we set out to make our own heat exchanger for the GT500, we set out to achieve the absolute highest cooling capacity available. We have achieved just that with our 07-12 GT500 heat exchanger. Our triple pass design is the only one of its kind on the market, all others are single or double pass units.
Many competitive units are advertised using outside dimensions that are passed off as actual cooling area dimensions, meaning a unit being shown with 2 inches of thickness outside but actually only has 1 1/4 inches for the actual core itself making it hard to make true comparisons. Our true core thickness coming in at 1.7 inches is larger than any other dual fan heat exchanger on the market.
Our triple pass design along with the largest true core thickness and powerful dual 800+ CFM fans allowed us to achieve 18% more heat rejection than the closest competitor, making this heat exchanger the superior choice for all uses including street use and in particular, road racing where long periods under constant boost generates constant heat that needs to be dissipated.
In addition, we went the extra mile and designed a true plug and play harness for the wiring of the fans requiring no wiring work. No cutting, splicing or soldering of any kind will be needed making it is truly plug and play. Our heat exchanger is an easy, direct bolt on replacement that is manufactured from high quality aluminum and fully TIG welded. It is also fully bushed for isolation from vibration which can cause premature failure of the unit.
Pair this heat exchanger with Ford Racing's Upgraded GT500 intercooler for the ultimate supercharger cooling upgrade!
This unit also works with 2005+ GT models with Whipple and Magnuson Superchargers with minor modification.
Product Benefits
  • TRIPLE Pass Heat Exchanger - others are only single or dual
  • Plug and play fan wiring harness - no cutting or splicing
  • 18% more heat rejection than closest competitive unit
  • A must if you road race your GT500 and a superior unit for street use
May 3, 2026 05:42 AM
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
Sep 24, 2015 08:15 PM
