GT500 Brake Rotors.. cross drilled?
I've read a lot about the GT500 rotors being cross-drilled, and have seen plenty of pics showing the same
however, from the threads related to retro-fitting GT500 brakes, i noticed the rotors are solid
can anyone please confirm?
are the rotors cross drilled? if not, is it an option to have them drilled and/or slotted?
so basically if i'm not mistaken, the rear brakes on the GT500 are the same as those fitted on standard GTs, with exception to the Brake Pads.
however the front brakes are 14" vented Brembo rotors with 4 piston calipers
this is despite most of the media showing drilled front rotors..
The concept car had cross drilled brakes. You may be seeing those in pics. As Pace said, the real ones are only vented. In reality, cross drilling is really only good for looks. They have a tendency to crack when heated up.
The rears on the Shel are 2-piston while those on the GT are single piston...
As a matter of fact, the latest dealer parts catalogue shows the same part numbers for the rear brake assembly on both the Mustang GT and the Shelby GT500, except for the rear brake pads (7R3Z-2200-A)
apart from that, rears are exactly identical.
The Shelby Rear Caliper Part Numbers were only recently Listed. I can not confirm the Differences Between the two phyically yet. I did Compare the Shelby vs Gt Pads and Found no Physical diferences.
KC
KC
