Dyno-Tuning the 07 Shelby GT500...505 RWHP
Old Sep 13, 2006 | 07:30 AM
Justin00Stang's Avatar
Today Jerry and myself got the opportunity to work on a gentleman's brand new GT500. With just over 1000 miles on the odometer the car still smelled like new.
All runs were done on an industry standard Dynojet 224x, you can't fudge these #s like other dynos. 93 octane pump fuel was in the tank.
We ran the car 3 times stock to get the drivetrain up to temp and get a good average HP #. The car made 421/438, then 424/427, and 419/22. I would say the blower and engine are very sensitive to heat soak.
On every run we monitored air/fuel with two widebands, boost after the blower/intercooler, and restriction before the throttle body. We also datalogged a myriad of parameters with the SCT X-Cal2 and Live Link datalogging software.
The stock tune has no timing in it at all, it's really quite disgusting. With the stock tune the air/fuel came in a little lean below 2000rpms, ran 11.5 through the mid range, and hit high 10s past 5000rpm. The car makes about 9psi of boost in stock form, just like the guage on the dash says. With the stock airbox the MAF is almost pegged, reading 4.95v.
Now that we had some good data on a stock car we started playing with the tune. When it was all said and done we arrived at 482RWHP and 477RWTQ, no you're not reading that wrong, that is approximately a 60RWHP gain. This was not a money shot either, the car was ran 11 minutes before and made 481RWHP/476RWTQ on the previous run. This was no ragged edge tune either, the Air/Fuel was 11.5:1. I was not about to blow up a brand new and very expensive car just to be an internet hero. We did not have time to let the car cool for a money shot. I was so excited that I started on the intake install right away.
I whipped up a prototype intake the night before with parts I had laying around. I took a piece of 4.5" aluminum tubing, a 4.5" cone filter, and a little CNCed aluminum flange that I had made a while back. The flange allows you to mount a slot style mass air sensor into a tube. It wasn't much, but it would give us something to play with. We had to retain the stock tube that passes between the Strut Tower Brace and valve cover. The tube is rubber with a plastic insert to keep it from collapsing, I'm sure it's restrictive, just like the stock airbox and panel filter. An aftermarket tube with thinner walls would flow a lot more air and still fit between the valve cover and STB.
The air intake required some tuning because the mass air sensor was installed in a new tube. This totally throws off the air/fuel and requires that the maf transfer function be redone, however an experienced tuner can do this in a few pulls. With the prototype intake the car made 505 RWHP/487RWTQ. Simply amazing, with the new intake the car picked up a slight amount of boost past 3500rpm, about 1psi peak at 6000rpm. The sensors were still measuring a little bit of intake restriction though, so the rubber tube between the maf housing and throttle body definitely has to go. I ordered a piece of 4.75" silicone hose, but it did not arrive until after the dyno testing was done today.
Tune with stock airbox vs tune with air intake, shown with boost.
Stock vs tuned vs tune+intake shown with air/fuel.
This car has a supercharger inlet pressure sensor between the blower inlet and throttle body, this will be handy for measuring various inlet restrictions. In the next few weeks I should have a throttle body to test.
The best part is the car feels just like stock until you romp on it. A quick 1-2 shift can now get you in trouble, even with TCS on.
We disconnected the exhaust after the X pipe, it was only worth a few HP.
I've debated whether or not to post this pic of the intake I made. Namely because its very simple and easy to duplicate. However, since I'm mainly in the tuning business I've decided it does not really matter.
A word of warning to all Shelby GT 500 owners out there. This car has a totally unique electronic control system, not seen on any other Ford (not even the Ford GT). The drive by wire system will take power away if you pulley the car, and then add it back in slowly. The car could be given what is thought to be a *safe* tune on the dyno, but then blow up a few days later.
I am still looking for several more of these cars to work on. If you are in the Central Florida area contact me.
Old Sep 13, 2006 | 12:25 PM
Sharp's Avatar
Awsome, I want one BAAAADDDDD. (but not over MSRP bad.)
Old Sep 13, 2006 | 06:54 PM
GOFISCH's Avatar
80+hp on a tune and a intake? WOW
Old Sep 14, 2006 | 09:18 AM
Stangette's Avatar
This setup, stock, as we all know; is really de-tuned.
505 rwhp.....nice.
With an imprved CAI Tube, she might go to 530 at the wheels. Sweet with the CAI and a tune for sure.
Old Sep 14, 2006 | 09:31 AM
shelby_sez's Avatar
I'd be curious to know...
what did happen a few days, weeks, months after this tuning.
Also for those of you in GA and FL, you might be interested in this. It's really a very good show in a fantastic venue.
www.mmjax.com
Click the Photo Gallery link, and then 2006, scroll down to the 'JMC World Golf Show' that was held this past May.
Love,
Judy
Old Sep 14, 2006 | 01:19 PM
snkbtn99's Avatar
Would be nice to have a little more detail on this statement.
Great job though!
Old Oct 30, 2006 | 08:14 PM
I dynoed this car again a few weeks ago and it was making more power stock and tuned, due to some break-in miles and slightly cooler air down here in FL.
Old Oct 31, 2006 | 08:14 AM
shelby_sez's Avatar
Ran into a Ford factory rep at dinner last night. He said that when you have your first oil change done, presumably at a Ford dealer, to have them 'flash' the chip to be sure that it is producing all 500 hp. He also said that from the factory, they are detuned to the neighborhood of 350 hp. Quite a difference!
Anybody else heard similiar?
Old Oct 31, 2006 | 08:37 PM
Complete garbage info. Only 350hp?!, Ford does not want another 99 Cobra fiasco...they do some things to specifically guard against this.
Old Nov 1, 2006 | 07:07 AM
Stangette's Avatar
Yes, with less than 800 miles so far, my Snake drives like she has every bit of her 500 ponies In working with Ford, it is my knowledge that she will become a bit more responsive with seasoning and that is about it.
Old Nov 1, 2006 | 07:50 AM
shelby_sez's Avatar
Linda,
How were you able to determine that your Shelby was #860? I'm wondering what mine is.
Judy
Old Nov 1, 2006 | 11:40 AM
Stangette's Avatar
Originally Posted by shelby_sez
Linda,
Judy
The Dealer believes it is according to a method to read the VIN - but it is curerntly being verified by Corporate. Many longtime SVT Cobra Club Members believe this is a close determination as well. So, i will not make final determination until the SVT Certificate comes in at the end of the year.
the last 6 #s of the VIN --- 195860 --- the "860" ---- many Shelbys i have seen, their first 3 numbers of this sequence is 210 - indicating a later build. Angel was built within the first six weeks of production. I have the order sheet from the Ford where the car was shipped from the Factory and Sold to my Dealership. The date is on there.
Old Nov 1, 2006 | 12:28 PM
shelby_sez's Avatar
interesting.. i have all my paper work at home, ill have to check it.. the first 3 of my last six is 208. it arrived at my dealer on august 14th....build was in june as i remember, but not absolutely sure...
09-gt/cs
Oct 15, 2015 10:03 AM
CoyotePremium13
Oct 7, 2015 07:17 PM
