Winter Sleep, Oil question.
The time is coming and Im about 2-3 weeks from letting her go to sleep for the winter. I don't do much miles on it, last year managed to put on 3000 miles, and let the dealer change the oil ( xo5w20qfs ) before I winterized the car. This year I just put in 2500 miles on it, and questioning if I should change the oil now before winterizing, or wait until spring and then change it?
At the same time I'm planning on doing the oil change by myself , with royal purple oil/filter.
Should I even consider changing it after just 3000 miles? the more and more I read about synthetic oil, the more it points to 5000 mile intervals minimum. Dealer put in synthetic oil (xo5w20qfs ) , but their sticker on the window states to come back after 3000 miles.
The time is coming and Im about 2-3 weeks from letting her go to sleep for the winter. I don't do much miles on it, last year managed to put on 3000 miles, and let the dealer change the oil ( xo5w20qfs ) before I winterized the car. This year I just put in 2500 miles on it, and questioning if I should change the oil now before winterizing, or wait until spring and then change it? At the same time I'm planning on doing the oil change by myself , with royal purple oil/filter. Should I even consider changing it after just 3000 miles? the more and more I read about synthetic oil, the more it points to 5000 mile intervals minimum. Dealer put in synthetic oil (xo5w20qfs ) , but their sticker on the window states to come back after 3000 miles.
Yeah these cars can go past 5K miles no problem on synthetic. It's why the 5.0 has an 8qt pan compared to a 5-6qt pan on a normal car. It affords you longer oil change intervals.
When you "winter" your car, do you leave it untouched in the garage all winter? Or do you start it up and drive around the block every so often?
I use the mileage indicator to judge my changes. I drive on average, 400 to 600 miles a week, so I use good quality synthetics, and run them to the max.
Yeah these cars can go past 5K miles no problem on synthetic. It's why the 5.0 has an 8qt pan compared to a 5-6qt pan on a normal car. It affords you longer oil change intervals. When you "winter" your car, do you leave it untouched in the garage all winter? Or do you start it up and drive around the block every so often?
I literally do not do any "winterizing" on the car… I just simply don't drive it but start her up every two weeks or so with a battery trickle charger of course.
To the original question of the thread, I only change oil once a year with Amsoil full synthetic.
Yep... This is what I do minus the driving around the block. If there's snow or any condensation or salt on the ground my car does not touch it.
Rule 1) Depending on how tight and clean your engine runs, oil that has been run for a period of time will have combustion acids in it. It’s best to dump that oil in favor of fresh oil prior to storage. After changing the oil, start and run the engine long enough to get it THOROUGHLY warmed up to operating temperature, including the oil (A 20 to 30 minute drive should do). This coats the engines internal surfaces with fresh, acid free oil that is relatively devoid of moisture.
Rule 2) Never start an engine that is in storage unless you plan to run it hard enough and long enough to boil all the moisture produced by the cold start, out of the inside of the engine, including the oil. A start and idle for 20 minutes isn’t going to do it! In fact it will do more harm than any good it is intended to provide, no question. Moisture will build up inside the engine and exhaust causing corrosion (Yes, I’m aware Ford uses SST for most of its exhaust components…I’m also aware that even SST corrodes!).
The best treatment you can give your Coyote is to change the oil just before hibernation and take it on one last short cruise to make sure everything is at operating temp and has had enough time to boil off any moisture produced during the cold start (20 to 30 minutes). Park your steed where it’s not going to be bothered for the rest of the storage period and put a battery tender on it. Every two to three weeks go out and turn the key on, matt the accelerator (Which during an initial start shuts the fuel off to the injectors so it won’t start) and crank the engine for a second or two. The relocates the cam load to different valve springs and re-lubes the cylinder walls without building up combustion moisture and acids. Any condensate that may naturally occur through normal ambient temp and humidity cycles will be water only and very minimal. This moisture will boil away on your first 20 minute ride when you wake her up in the spring.
I know some people swear by fuel stabilizers but I firmly believe they no longer have any relevance in modern cars with tight fuel systems using EFI. Permeation, evaporation and oxidization are the enemies. The fuel is so tightly contained in these new systems, it can’t evaporate or permeate through its components. The only oxygen that can get at it is in the void space in the fuel cell and that’s minimal. Once the oxygen in the air inside the cell has reached its saturation point, it really can’t break any more fuel down until more oxygen is made available. Case in point: Years ago we received a Navy SBD that was lost to the depths of Lake Michigan after the cat launch failed and dumped the airplane overboard. We received the airplane shortly after its recovery and found the fuel cells were still intact and full of fuel. The fuel was as fresh as the day it was pumped into the airplane…no oxygen, tightly sealed and fresh after a 60 year swim in Lake Michigan.
My 2 cents guys and gals,
John
I change every fall before storage regardless of miles driven that summer.
Don't be fooled - this pic is on fresh oil:
I still am not sure about the self oil change = tick, myth. Some/most folks (like me for example) who changed the oil since very low miles never had the tick. Not sure if it's a latent defect of their actual engine from the get go or what...
With the quality synthetics and filters that are available these days, they can go 10K between changes. It's all in how they are driven. In the OP's case, he only puts on 2000 to 3000 a year, so he has to change the oil in the spring, as it sits too long.
I'm not trying to be argumentative, but I just wonder what would cause it to go bad other than heat and friction?
I have always let the dealership do the oil change, wanting to use 'Ford Recommended' products job done by Ford people. I believe they used Motorcraft Full Synthetic just like last time (this was a 2nd oil change).
This 'Tick' leads me to believe the Motorcraft stuff is not a great fit, at least not anymore. I might need to look into Royal Purple or Amsoil like many forum members prefer to use.
The tick is not a myth. I could care less until it happened to me, surprised to find out quite a few others are having the same issue. I have always let the dealership do the oil change, wanting to use 'Ford Recommended' products job done by Ford people. I believe they used Motorcraft Full Synthetic just like last time (this was a 2nd oil change). This 'Tick' leads me to believe the Motorcraft stuff is not a great fit, at least not anymore. I might need to look into Royal Purple or Amsoil like many forum members prefer to use.
Amsoil is sold by independent dealers - find one near you at www.amsoil.com.
Best stuff. I get mine from a buddy who knows a dealer.
