Window Sticker info
Old May 15, 2010 | 02:45 PM
nsthesa's Avatar
Window Sticker info
Besides the build date and blend # ( whatever that really is) what else can be decoded on the sticker?
Just curious...
Old May 15, 2010 | 02:59 PM
Rabbi Mike's Avatar
And it would seem that the blend number is meaningless to the consumer . . . is that right?
Old May 15, 2010 | 03:15 PM
PTRocks's Avatar
The Blend number is the number used to define the order the cars are built. The regular production #'s go from 0001-8xxx, and then start over again. Pre-production cars have Blend #'s in the 9000's.
Old May 15, 2010 | 03:25 PM
nsthesa's Avatar
Huh? my blend # is 2116
Old May 15, 2010 | 03:50 PM
PTRocks's Avatar
The number is only meaningful when combined with the build date shown before it. About 600 cars are built per day, in the order of the Blend number.
Old May 15, 2010 | 10:20 PM
tiresmokindad's Avatar
Re: Window Sticker info
Just curious...
I can give you the info of how to decode it. Just pm me for that.
Old May 16, 2010 | 07:04 AM
nsthesa's Avatar
So for my blend #( 2116) I would have to wait 3-4 days past 5/50 for it to be built? Then what happens to the cars scheduled for those days??? Something's wrong there!....
Old May 16, 2010 | 07:05 AM
nsthesa's Avatar
oops that's 5/20 ( not 5/50 typo)
Old May 16, 2010 | 08:01 AM
Gene K's Avatar
At least initially the Blend Number is the number the cars are scheduled to go down the line. 0001-8999 then the blend sequence starts over.
So if your 2116 is scheduled for 5/20 then 550 most likely would have been scheduled on 5/17 or 5/18.
That said Ive seen what you have seen. Initial scheduled dates are for week of starting with Monday so their should only be roughly a 2400 difference considering the 4 day production schedule. However the date on the window sticker is supposed to be the day your car actually is scheduled to begin its trip down the assembly line. I assume if say 100 cars had to be rescheduled because of a shortage parts then the other cars would keep their previous blend numbers so we could have blend numbers 700 apart run the same day although only 600 cars were made.
1. How do we end up with Blend 5436 and 7290 with Window Stickers showing the same date?
2. Are their different lines with different Blend Numbers?
3. If a car has to be rescheduled does it keep the Blend Number already assigned to it?
Old May 16, 2010 | 08:13 AM
GottaHaveIt's Avatar
decode
this is like a sample sheet they sent me when I recieved a certificate for a GT-CS
Old May 16, 2010 | 10:03 AM
Old Shadow's Avatar
My vin way off compared to what GottaHaveIt showed. I think the 2010 number/letter sequence changed.
Old May 16, 2010 | 11:04 AM
Rabbi Mike's Avatar
decode
Here's an updated VIN decoder from mustangattitude.com:
http://mustangattitude.com/mustang/2011vinmatrix.shtml
I still don't know what the codes on the top of the sticker mean . . . (e.g., "TRD" "BUMP" "FSCP" etc.)
Old May 16, 2010 | 04:29 PM
objoe's Avatar
Red face
Great link, thanks.
Old May 16, 2010 | 06:00 PM
Old Shadow's Avatar
Mike,
the VIN decoder worked great and is easy to understand. Thanks!
Larry
Old May 16, 2010 | 08:49 PM
RMS70's Avatar
See attachment for the codes that I know of based on my 2010 GT.
Attached Thumbnails Window Sticker info-ws_1zvb6a5140754_jpeg_w_codes_small.jpg
Old May 16, 2010 | 10:00 PM
nsthesa's Avatar
That's great....
Old May 16, 2010 | 10:23 PM
Funny I never noticed that Ford lists it right there on the sticker... "4-passenger sports car"
Old May 17, 2010 | 12:19 AM
pony racer's Avatar
one of the codes in the upper left corner.. FLR-000353 VA..
the VA stands for the state that its being shipped to.. your case Virginia
Mine Says FLR-001417 CT.. Connecticut
which is almost identicle to the shipping car # 101417
Old May 17, 2010 | 05:12 AM
PTRocks's Avatar
FLR - the plant name, in this case Flat Rock
the number after FLR is a sequential invoice batch number
The Batch ID is actually the invoice date 1st digit/letter is the year (same as in the VIN), second is to indicate the month, last two digits are the day
The single letter after th batch ID is the invoice type: N-normal, R-rebill, etc.
I believe the two digit number before the invoice number is the regional code
I've heard the single digit after the invoice number is the order type: 1-retail, 2-stock, 9-export, A-A plan, D-D plan, X-X plan, Z-Z plan, etc. I have also seen 4, 5, 8, C, L, M (internal?), T (internal?), W (internal?), Y (internal?)
iliveonnitro
Oct 7, 2021 06:31 PM
kponypower
Jun 17, 2020 07:17 AM
boz
Oct 1, 2015 04:47 PM
GLOCKer
Sep 28, 2015 05:20 PM
5.M0NSTER
Sep 16, 2015 08:00 AM
