Window issue when opening door.
Old Dec 8, 2020 | 01:38 PM
jayaddi's Avatar
I recently bought a 2010 Mustang GT and the day I bought it, I noticed when I try to open the driver side door the window takes a little bit to go down. It work perfectly on the passenger side. It’s like a delay in the window going down to be able to open the door. Can someone please help????
Old Dec 8, 2020 | 02:52 PM
awoychosky123's Avatar
Open up the door panel and check the rails, you may need a new driver side motor?
Old Dec 8, 2020 | 03:13 PM
Bert's Avatar
I saw your post on the other forum and understand you already tried the reset procedure.
I think I would try a little silicone spray lubricant on the channels and the edge wiper next, just to make sure it is not sticking, always looking for the easy fix first . . . then check the rails and motor like he said ^^^
Old Dec 8, 2020 | 04:01 PM
jayaddi's Avatar
on the edge of the window seal?
Old Dec 8, 2020 | 04:02 PM
jayaddi's Avatar
what would be a sign that the rails are bad?
Old Dec 8, 2020 | 04:04 PM
jayaddi's Avatar
Same issue
I have the same issue as this person but there were no answers in this thread.
https://themustangsource.com/forums/...s-trim-463122/
Old Dec 8, 2020 | 04:12 PM
jayaddi's Avatar
I get you can just hold the handle for a second and the window will go down, but when other people drive it they just rip the door open and it makes me cringe. I also would like to sell it one day and upgrade to a 5.0 and I don’t want that problem to be a way for someone to lowball me.
Old Dec 9, 2020 | 06:01 AM
Bert's Avatar
yes all around the edge where the window contacts the rails and the wiper along the top edge of the door
if you have tinted windows it might be a good idea to test it in an inconspicuous area first, just in case the silicone discolors the tint . . . I don't think it will be a problem because I have tinted windows and have used silicone on mine with no issues, but you never know
this might not solve the issue but I think it's worth a shot before you take the door apart
Old Dec 9, 2020 | 07:55 AM
dusman59's Avatar
Make sure to use 100% silicone for best results. Many sprays only contain very little silicone. The rest is petroleum distillates.
https://www.sofasco.biz/castle-big-5...xoCMkEQAvD_BwE
Old Dec 9, 2020 | 08:48 AM
they probably aren’t and it the motor, but if the rails are bad you would be getting rubbing on the edges of the glass where it rides. Might hear rubbing or odd noises when you roll it all the way down.
Old Dec 9, 2020 | 12:37 PM
jayaddi's Avatar
I’ll try that when I get home but it possibly is a bad motor. That’s not a big deal to swap out if so. Is the process of taking the rails and motor out the same as the 2005-2009 body style?
Old Dec 9, 2020 | 12:38 PM
jayaddi's Avatar
I don’t hear any noise. But when I roll the windows up, the driver side takes half a second slower to go up. So for sure the motor?
Old Dec 9, 2020 | 01:41 PM
Bert's Avatar
probably since they are practically the same car, but I don't know because I haven't done it . . . one of the other guys might know
Old Dec 9, 2020 | 03:20 PM
jayaddi's Avatar
is the process of taking out the rails/motor the same as the the 2005-2009 models?
Old Dec 9, 2020 | 03:56 PM
jayaddi's Avatar
Ordered the silicone lubricant. Going to try that before I take the tracks and motor out. Which isn’t a big deal since I’m about to have the door panels off to swap the factory speakers anyway.
Old Dec 10, 2020 | 04:39 AM
David Young's Avatar
Be sure to put an old blanket under the door. When I changed my door speakers, the panel dropped fast. Just a heads up.....
Old Dec 10, 2020 | 06:49 AM
yes just a few extra screws on the panel, so take your time.
Old Dec 10, 2020 | 03:13 PM
jayaddi's Avatar
shouldn’t be a problem then. Ive already had my door panels off for another reason.
jayaddi's Avatar
Thanks for all y’all’s help.
Spider
2007-2009 Shelby GT500
Jan 29, 2008 08:38 AM
70MACH1OWNER
Jan 23, 2008 09:50 AM
Louie
Oct 26, 2005 09:07 PM
Louie
Jul 24, 2005 05:23 PM
stangman60
Apr 18, 2005 08:20 PM
