Whipple 2.9L Crusher Ordered
Well, I just placed my order for the following:
3.750" (10psi) and 4.000" (8psi) Whipple Pullies
Ford Racing 47 lbs Injectors
Ford Racing Spark Plugs (1 stage cooler)
Ford Racing 65mm Throttle Body
JLT 127mm Carbon Fiber Twinscrew Intake
It's about to get real aggressive around here!!!
I'm doing my own install, and I should have the complete package in 2-3 weeks.
The 2.9L Crusher takes a couple of weeks before it's ready for delivery.
no words can describe how im feeling right now..........
thats going to be one awesome machine
your going to need some bigger tires asap...
Originally Posted by ShaneGT
next thing you will be doing is the Ford racing boost ready short block... that thing will shot the High compression pistons to china!!!!
That's the Aluminator you are referencing.
Originally Posted by mystickeith50
I am about to buy the same thing. Let us know how u make out, also where did u get the goodies?
AWESOME! Let us know how it goes; I'm thinking of going this route soon, too!
Oh, and if Lethal's stock-engined, 2.9L Whipple-augmented 2011 5.0L hasn't grenaded, yet, I think you'll be just fine.
haha, you should be fine with just 10psi, What type of fuel you will be running? 93 pump?
I've got a build thread over on S197Forum where I will detail the install. I think you're on there right?
It's in the Pictures and Video section titled, "S197 GT's 5.0 Build: It's Getting Real Aggressive"
I'll be fine with the stock block. I'm running low boost, and the timing will be at 15* tops.
Originally Posted by eliyarbrough
Sounds very cool! I'm thinking you'll soon need new tires, anyhow. If I bought this, I sure would burn through them PDQ!!
I'm looking at these.
Originally Posted by KonaBlue5.0
Are you planning to hit up Lund for the new tune, and if so, are you planning on sticking with the cammer?
No Ghost Cams this time around. After the tune is dialed in, I might add that, but not likely.
I'll keep you updated.
Awesome! You've seen what he was capable of on Lethal's car at 10 pounds of boost, right? Man, I'm definitely jealous!
