Whipple 2.9L Crusher Ordered
Old Aug 15, 2011 | 06:11 PM
  #81
MARZ's Avatar
Swamp Donkey Aficionado
Hey, man, I was wondering if you could do me a favor and take a picture or two of the discharge port and rotors located on the underside of the supercharger (assuming it's currently separate of the intercooler). Thanks!
Old Aug 15, 2011 | 09:34 PM
  #82
S197 GT's Avatar
3rd Times A Charm
Will do when I get there. Is that cool?
More grinding tonight...
Had to remove (2) water pump bolts to get more room.
Went back and smoothed out the bosses.
Old Aug 16, 2011 | 07:37 PM
  #83
MARZ's Avatar
Definitely! Thanks, man!
Old Aug 17, 2011 | 02:39 PM
  #84
S197 GT's Avatar
3rd Times A Charm
Finally got through the last boss!
Still cleaning up the cuts a bit.
Old Aug 17, 2011 | 03:22 PM
  #85
S197 GT's Avatar
3rd Times A Charm
Finally done with the timing cover grinding!!!
It wasn't that bad at all.
I used the following;
Dremel 4000
Dremel Reinforced Cut-Off Wheels 426
Straight Edge with mm readout
Sharpie Markers
I realized that my best way of doing it is first measuring out the 20mm mark on the semi-cut boss. I put a rough mark on the remaining bosses and ribs. There are no measurements to use, so you just have to use your judgement based on the drawings.
The (2) leftmost bosses are easy to get to and really don't require any special notes to follow. The semi-cut boss will require you to remove (2) bolts on the water pump and also the cross section where the upper radiator hose meets the engine. I cut several "slices" into the boss in order to chip away at it leaving room for my Dremel. Once I had a decent amount of material removed, I ended up using the cut-off wheel in a grinding fashion. I turned it 45* and used a side to side motion to bring the surface down even and flush. It works quickly too! Much faster than cutting away at it.
I accomplished the task of grinding the front cover with just a Dremel!
Old Aug 17, 2011 | 06:35 PM
  #86
stangfoeva's Avatar
MOTM Committee Member
Excellent work so far! The smoothing out looks pretty good
Old Aug 20, 2011 | 11:25 AM
  #87
S197 GT's Avatar
3rd Times A Charm
Got a decent amount of work done last night. Most of the time was spent trying to decipher the **** instruction manual.
Luckily for you guys, I'll break it down.
The kit comes with some very nice extension harnesses so that there is very little splicing.
First up is the throttle position sensor. TPS.
You need to unwrap the electrical tape from the TPS and rotate the harness so that the wires are all straight.
Next you want to open up the loom to give you room to work.
You wanna disconnect the "connector" on the TPS harness. This is the red piece that is inside the harness. You do this by gently prying on it with a thin pick.
Once you remove the red connector, you can pry of the back of the harness with the same pick to release the back portion of the harness.
This will have affectively opened up the harness and enabled you to cleanly remove the wires from the harness.
You take the small pick and insert it into the slot above each wire retainer. Gently lift with the pick and the wires will pull right out.
Now that you've exposed all of the wires, you need to grab the TPS harness extension which is included in the kit. Find the TPS connector on the new extension.
Depress the locking tab and separate the male and female ends of the harness.
What you need to do is replace the old TPS harness connector with the new one from the extension.
Follow the same steps, remove the red connector from the inside of the new harness.
Pry off the back of the new harness. Slide the new back piece onto the exposed TPS wires being sure to note the proper wire configuration. Slide each wire into the back of the harness and you will feel it lock into place.
Slide the back of the harness up to the harness itself and snap it all together. You've just finished swapping the harness connectors on the TPS.
Tape up the loom and exposed wires and the feed the extended harness along the passenger side coil cover and along the back of the valley towards the rear of the driver's side head and use zip ties to secure the harness.
Next up is the purge valve.
This is a similar process, you remove the red connector inside of the Purge Valve harness. Slide the pick into the slots above the wire retainers and pull the (2) wires out. Be sure to note their orientation.
Take the new extension harness for the purge valve that is included with the Whipple kit. This is where it's slightly different. There is nothing to take apart on this harness.
Depress the locking tab to disconnect the harnesses. Take the female section of the harness and you'll notice (2) holes. Slide the exposed wires from the factory Purge Valve harness into this new harness. They will lock right into place.
Now you can connect the new extension to the existing harness and route them along the TPS extension towards the rear of the driver's side head. Be sure to zip tie them as well.
(to be continued)
Old Aug 20, 2011 | 03:53 PM
  #88
dafreeze's Avatar
Blower in my future and have printed off and poured over the install instructions from the Ford Racing site for their 2.3l. Trying to determine if any differences in their 2 Whipples....parts list no help as blower and pully components listed as NPN (no part #). Pondered pullying down the 624 until I can re-inforce my internals and drivetrain, but more research required on my part. Now you've given me more to consider. (pardon my ignorance...I too had reason to think this much to the Coyote might be excessive).
Like others, really appreciate you taking all the extra time to document this.
Curious if you were to do it again, would you use the same method (dremel) to take care of the inside of the timing cover? I've got a hax saw and an angle grinder and this chore is what I'd concluded would be the only pither (typed with a lithp).
Old Aug 20, 2011 | 08:00 PM
  #89
S197 GT's Avatar
3rd Times A Charm
Next up is the Intercooler Pump wiring.
There is a stud next to the underhood fusebox. You need to remove the nut and harness from the stud.
You need to install the relay from the Intercooler Pump Wiring Harness onto the exposed stud. You want to install the fuse previously removed onto the same stud.
We had to drill the hole a bit on the relay to get it to fit on the stud.
There is a red wire attached to the Intercooler Pump Wiring Harness. You'll need to route the red wire to the positive post at the back of the fuse box.
You then take the other bundle of wires and route them forward around the front of the fusebox and along the factory lamp harness.
Remove the bolt securing the factory grounds behind the passenger side headlight and secure the factory grounds along with the grounding eyelet from the Intercooler Pump Wiring Harness.
Route the single wire with (2) connectors along the factory engine harness to the rear of the passenger side head.
Connect these connectors inline with the passenger side radio capacitor.
These are hard to see and even harder to get too. Just keep feeling around for the 2 connectors, and you'll find them low behind the passenger side head.
I unplugged the (3) PCM connectors to get to the bottom most 70 pin connector.
I removed the front connector.
Then I removed the wire support on the back of the connector.
I then took the supplied Air Charge Temp sensor loom which has the ACT sensor on one end and (2) wires on the other end. 1 wire has a pin crimped on it, while the other has a blunt end.
I pulled pin C-56 from the PCM harness.
The blunt ended wire from the ACT sensor loom needs to be spliced with the wire from pin C-56.
I happened to solder mine and use hear shrink.
The wire from the ACT sensor loom with the pin will slide into the empty slot of C-36.
(to be continued)
Old Aug 20, 2011 | 08:31 PM
  #90
S197 GT's Avatar
3rd Times A Charm
When I went to reinsert the soldered together connection for pin C-56, the pin broke off.
I'm searching everywhere to get this pin, but I'm not getting any luck.
Here's the pin.
Since the pin broke, I just left the PCM harnesses disconnected and I moved on.
Next I extended the Mass Air Flow Wiring. I did the exact same thing as for the TPS and for the Purge Valve.
The kit comes with a MAF extender harness, and you just swap out the OEM harness for the one provided in the kit.
The only thing to note is that the new connector has (6) pins, but the MAF only uses (4) wires. For this, you only use pins 2-5 and leave both 1 and 6 empty.
Make sure the wires are all locked in the new harness and that the colors match on both side of the connection.
Once this is done, neatly tuck the MAF wires back into the wire loom and use electrical tape to seal the loom and complete the extension of the MAF.
Now things are in full swing!
Next up is reorienting the knock sensors. They are located in the middle of the valley between the heads.
Each knock sensor has a 90* plastic wiring retainer that will need to be discarded. Unclip the retainer and undo the electrical tape to remove them.
Loosen each bolt slightly and rotate each knock sensor towards their respective side. The driver's side knock sensor should rotate closer to the driver's side head, and vice versa.
Torque the bolts back down to 25Nm.
I then gapped my new Ford Racing 1-Step Cooled plugs down to .030".
I then swapped the plugs.
Pretty simple, pull out the coil covers, release the harnesses on each COP, remove the bolt securing each COP, pull out the COP to expose the plugs.
I'm at 10,000 miles, so my plugs cane out with no problem.
The order of the plugs in the pic above reads 5-8 on the left side going top to bottom, and 1-4 on the right side.
Here is my #8 plug.
I installed all of the plugs, the COPs, and the coil covers.
Next up was the Intercooler Low Temperature Radiator (Heat Exchanger).
I installed a rubber grommet into each of the (4) mounting tabs located at each corner.
I ran a sleeve through each grommet, and then ran a bolt through the sleeve and grommet into each corner's mounting bracket.
There is a little NVH insulator pad that is adhered to the front if the heat exchanger. Just measure 170mm from the top and 140mm from the right and adhere the NVH insulating pad to the heat exchanger.
Next we take the Fuel Charging Assembly (lower manifold) and attach a rubber hose from the PCV Purge Hose to the barb on the bottom of the Fuel Charging Assembly.
Next up is relocating the Purge Valve. The instruction manual I received is for the 2.3L kit which is slightly different.
In this case, the 2.3L utilizes a throttle body spacer as a part of it's inlet system and the Purge Valve is relocated to this throttle body spacer.
In my case, with the 2.9L, there is no throttle body spacer. The Crusher inlet runs from the back of the blower all the way around to the throttle body in one clean piece.
I've reached out to all my resources, but nobody seems to know where the purge valve gets relocated to.
I'm going to have to figure this out.
This is where I stopped for the day.
(to be continued)
Old Aug 20, 2011 | 08:42 PM
  #91
S197 GT's Avatar
3rd Times A Charm
Great questions.
The only difference I've noticed so far between the 2.3L kit and the 2.9L kit is what was highlighted in my last post.
There is no throttle body spacer on the 2.9L because it uses the Crusher inlet. The 2.3L has a rather large throttle body spacer that has the spot to relocate the purge valve.
The 2.9L comes with a 2.3L install manual. So it is of no help in finding where this is supposed to be relocated.
So the differences is the install manual, and the purge valve relocation. At least that's all I've ran into thus far.
The 2.9L pulleys start at 4.00" for 8 psi and go down a quarter inch for every 2 psi. So, 3.75" = 10 psi, 3.50" = 12 psi, etc.
I believe the 2.3L starts 8 psi with a 3.50" pulley. I may be mistaken on that, but they are certainly not the same pulleys for the same amount of boost.
I would definitely use a Dremel again. Everything else is too big. Even a hacksaw is kinda big.
I bought a mini hacksaw to help, but I couldn't use it.
If I had to do it again, I could knock out the grinding in 40 minutes.
Dremel, reinforced wheels, 45* grinding rather than cutting. That's the trick.
If you do get the Whipple, I'd be happy to give you any pointers for your install.
I'm getting pretty **** familiar with this kit, by not only installing it slowly and carefully, but also by documenting this install.
I'll give you my number if you need and I can walk you through any of it.
It's been a lot of fun. I'm stoked for it to be done, but I'll be yearning for another project!
Suade headliner is next after this. I'll be doing the job on that too.
Old Aug 21, 2011 | 08:25 AM
  #92
mystickeith50's Avatar
Great write up man. Taking the extra time to document this will help a lot of people. Just got my car done and it's well worth the wait for u.
Old Aug 21, 2011 | 09:27 AM
  #93
S197 GT's Avatar
3rd Times A Charm
Thanks man. What'd you pay for the install?
Old Aug 21, 2011 | 09:38 AM
  #94
Well it's kinda embarrassing to say the least that I didnt install it myself. With all my other cars in the past I have always done everything including the engine work...now with my schedule and work, I just don't want to do it. With that being said...lol...I paid 700 bucks for the full install and that was with also installing the boss oil cooler which is pretty easy, and I paid Lund almost 500 for the custom dyno tuning. I must say though, the timing cover grinding came out flawless...flawless. But fwiw, you can't even really see it with everything connected back up to the front.
Old Aug 24, 2011 | 10:22 PM
  #95
S197 GT's Avatar
3rd Times A Charm
Started off the night marking and drilling a 5/16" hole in the fan shroud to mount the Intercooler reservoir.
Then I clipped on a J-clip in the hole and mounted the fan shroud.
Then I mounted the Intercooler reservoir using hardware supplied in the kit.
Then I removed the (4) bolts/nuts on each corner of the radiator. The radiator will stay in place.
I mounted up the heat exchanger using the same (4) mounting points on the radiator.
I used (2) bolts supplied with the kit in the top corners, and reused the factory nuts on the bottom.
Not much room between the heat exchanger and the radiator.
Next I routed the intercooler pump hose from bottom of the intercooler reservoir and along the side frame and out the driver's side radiator shield/air inlet.
This picture has the INCORRECT orientation of the hose coming from the reservoir.
It should go underneath the radiator hose and routed like this.
(to be continued)
Old Aug 24, 2011 | 11:06 PM
  #96
S197 GT's Avatar
3rd Times A Charm
Then I mounted both radiator shields.
I removed the top inner (2) bolts from the bumper beam. I replaced them with longer replacements from the supplied hardware.
I then installed the intercooler pump bracket along the inside of the bumper beam by utilizing the bolts from the previous step and the studs just below. I used the (4) supplied nuts to secure the bracket to the bumper beam.
I then installed another NVH cushion on the back of the bumper beam measuring out 220mm from the driver's side bumper support bracket and 60mm in from the front of the bumper beam.
The intercooler pump mounts to the bracket with (2) supplied bolts. The pump sits perfectly between the NVH cushion installed in the last step and the NVH cushion installed on the heat exchanger earlier in the install process.
The hose from the intercooler reservoir goes to the side of the pump when installed. The other jose goes from the bottom of the pump up to the driver's side of the heat exchanger.
To finish it off I ran the wiring from the intercooler pump under the main harness, along the back of the passenger side headlight and down through the passenger side radiator shield. I ran it down to and along the intercooler pump bracket and plugged it into the pump.
The instructions said to use the clips from the harness to mount it to the bracket, but there were none. So I used zipties in the holes of the bracket to secure the harness.
The last step of the evening was mounting the bumper support foam back to the bumper beam using the factory Christmas trees.
Next up is MOUNTING THE BLOWER!!!!!
Old Aug 27, 2011 | 09:20 AM
  #97
S197 GT's Avatar
3rd Times A Charm
Teaser:
Old Aug 27, 2011 | 12:06 PM
  #98
MARZ's Avatar
Teaser:
You didn't happen to snap any photos of the discharge port / rotors, did you?
Old Aug 27, 2011 | 12:09 PM
  #99
S197 GT's Avatar
3rd Times A Charm
Come on now. I didn't forget about you.
The blower is off the car. We were testing fitment, and more so, I wanted to see what it looks like.
The tape is still on the bottom, but once I take the tape off, I'm taking some pics for you.
Old Aug 27, 2011 | 12:56 PM
  #100
MARZ's Avatar
Haha, thanks, bro! I was going to order you a couple cases of skunky beer had you forgotten about me. That'll teach you!
