Where to pick 12VDC for Added fog lights
I have a 2014 GT and I added lower fog lights. What fuse number in the 'under hood fuse box' can I pick up 12VDC that switches on/off with the ignition key? I looked at the manual and I don't see anything switchable in that box but htere has to be one there.
I don't know the answer to your question but will be interested to see how you hook everything up. I have been wanting to do this to my 14 GT but don't know how to wire it up so that it doesn't overload any other wiring.
Wayne
Wayne
http://www.oreillyauto.com/site/c/de...yword=fhm200bp
you NEED to use a relay, do it right. fused power directly to battery, use PCM fuse as +12v trigger. relay diagrams are easily found on google if you need to figure out how to hook it up.
Just chiming in to say USE A RELAY. You will not have any issues with the use of a relay. If you try and run power from a circuit directly to what you're powering, you greatly increase the odds of having issues. Wiring is designed for a certain amount of load. If this load is increased it could potentially shorten the life of your wiring, melt the insulation, melt the connectors, and even cause a fire.
