Where to pick 12VDC for Added fog lights
Old May 25, 2014 | 09:05 AM
elkk's Avatar
I have a 2014 GT and I added lower fog lights. What fuse number in the 'under hood fuse box' can I pick up 12VDC that switches on/off with the ignition key? I looked at the manual and I don't see anything switchable in that box but htere has to be one there.
Old May 25, 2014 | 11:19 AM
For my intercooler pump, I used the 5A PCM fuse, F45. Otherwise you could use the actual ignition switch fuse under the passenger glove box.
Old May 25, 2014 | 02:55 PM
70monte's Avatar
I don't know the answer to your question but will be interested to see how you hook everything up. I have been wanting to do this to my 14 GT but don't know how to wire it up so that it doesn't overload any other wiring.
Wayne
Old May 26, 2014 | 02:26 AM
elkk's Avatar
Wayne
Wayne, I am going to use this Add-A-Circuit when I find the proper fuse # to use. I will try fuse 45 tomorrow.
http://www.oreillyauto.com/site/c/de...yword=fhm200bp
Old May 26, 2014 | 06:56 PM
WhiteBird00's Avatar
DO NOT run fog lights off the 5A PCM fuse without a relay. The factory fog lights are on a 15A circuit with a relay so 5A is nowhere near enough.
Old May 26, 2014 | 07:40 PM
houtex's Avatar
I was going to recommend this very thing. Use a relay. Don't use the factory wiring for add ons except to get an 'ON' signal to the relay, then off to the add ons.
Old May 27, 2014 | 08:05 AM
bones302's Avatar
+3
you NEED to use a relay, do it right. fused power directly to battery, use PCM fuse as +12v trigger. relay diagrams are easily found on google if you need to figure out how to hook it up.
Old May 27, 2014 | 08:14 AM
RubyRedMCA_Beast's Avatar
Just chiming in to say USE A RELAY. You will not have any issues with the use of a relay. If you try and run power from a circuit directly to what you're powering, you greatly increase the odds of having issues. Wiring is designed for a certain amount of load. If this load is increased it could potentially shorten the life of your wiring, melt the insulation, melt the connectors, and even cause a fire.
Mpaps
Oct 11, 2017 08:06 PM
scott6809
Sep 12, 2015 11:44 PM
14Glassback
Sep 11, 2015 04:50 PM
earl610
Sep 6, 2015 05:48 PM
Kestral
Sep 2, 2015 06:52 PM
