When to shift in the new 5.0???
Old Aug 8, 2010 | 09:26 AM
  #41
JobeNole44's Avatar
For those that start in 2nd, does this wear out the clutch faster than starting in 1st? I have done this several times and it seems like I have to ride the clutch a bit to keep it from clunking. Also, what is the actual fuel savings from skipping gears, starting in 2nd? How much do you save compared to shifting through all 6 @ 2-2.5k? Just wondering if it is worth it from clutch life to fuel savings...
Old Aug 8, 2010 | 12:37 PM
  #42
Jott's Avatar
Hmmm, well i don't start in 2nd from a stop, only from a roll. Skipping gears is easier on your clutch and your wallet.
Old Aug 8, 2010 | 08:51 PM
  #43
todd03blown's Avatar
Ducky = New ECI?
Old Aug 9, 2010 | 09:52 AM
  #44
nemosgt's Avatar
Originally Posted by assasinator
you picked a **** poor time to relearn how to drive a manual. a 430hp car will get you wrecked. just sayin man. its a lot of car to start in.
Not necessarily so. Depends how mature and conscientious one is. You can kill yourself in any car. Even a Toyota as we all know. Though I would recommend a performance driving school or take up auto crossing if one is serious about becoming a good driver. But of course this is a good idea for anyone with any car.
Originally Posted by 2k7gtcs
This whole thread is pointless now. The OP received his info and is getting a feel for it.
Drive the car any way you want. If you wanna drive like a grandma that's fine. It's your money.
I'd rather drive it like I stole it though.
Agreed. We've covered most of the points and it's starting to get personal now.
Cheers.
Old Aug 9, 2010 | 11:03 AM
  #45
That would be my concern. Same for the 4.6/5spd guys with 4.10's that start in 2nd. Maybe if on completely level with some slight forward movement.
My old F150 is a 4spd - actually a 3 spd with a granny gear so you normally do start out in 2nd. Even though 1st is so short, if I'm on an incline I'll use it so I don't put any extra wear on the clutch. I got 218k out of that clutch and when I put a new motor in and replaced the clutch, it mic'd almost the same thickness of the new plate.
Old Aug 9, 2010 | 03:25 PM
  #46
xkornkidx01's Avatar
That's right in the skip shift range. I say shift above 3000RPM from 1st to 2nd, then have fun and forget about fuel mileage.
I have said this many times, the only time I think about gas is when Im filling up and when that light comes on to remind you that you are running low...
Old Aug 9, 2010 | 06:07 PM
  #47
Originally Posted by Ducky
Best advice in my opinion. I tend to shift around 2k because the 3.73's make each gear so quick that shifting at 1700 would be tedious. Once you are actually driving though, I find 1k rpm to be a good thing to aim for. Too much lower and you could lug the motor, too much higher and you are wasting gas. I go to 6th above 30 mph.
I shift at 3k and I have 3.73's on my '10 and I have a 2.6L intercooled KB.
Old Aug 9, 2010 | 06:13 PM
  #48
Just drive the car and have fun!
Road_Runner
Sep 2, 2024 04:46 PM
Gigantor
May 11, 2023 07:31 PM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
