Wheel Gap Surprise
Wheel Gap Surprise
So... Up until a couple weeks ago I had a 2012 Blue Mustang GT. Never quite understood all this talk about the ugly wheel gap. Didn't seem too bad to me, and quite frankly I was very concerned about bottoming out if I went any lower.
Now I have 2014 Gray Mustang GT with the Track Pack. Holy cow I can get my whole fist in there. Now I get it. I'm wondering if it is the stiffer suspension or if it is the dire diameter of the 18" vs 19" wheels that causes the worst gap.
Below are a couple photos and there is at least an inch or more difference in the wheel gap. Note that the blue one has aftermarket wheels on it, but those are stock size tires on both cars.
Maybe I half answered my own question. Checked the tire calculator on AM and the 18" wheels are 27.25" tall and the 19" are 27.68" tall. So there's almost a half inch. Rest must be the stiffer springs not compressing as much?
By the way, pretty car.
The blue car was bought new. Not lowered. It never really had a lot of wheel gap and I would hit the curb with the front valance. The new car has more clearance.
....the slammed/camber stance craze started with imports
...which is actually accomplished in large part by lowering the motor mounts and leaving the suspension alone. This also allows the vehicle's suspension to function as it was meant to without compressing components and having to relocate others in order to keep the suspension functioning adequately.
That only lowers the center of gravity where the engine is located. When someone lowers a vehicles suspension, they are lowering the complete CG while also affecting the weight transfer, allowing the car to handle more efficiently.
I know about lowering motor mounts, I did it to my pro-touring car a few years ago, but I'll just leave this here for you. With your theory, you could take a truck and lower the engine and the truck will handle better, which is not the case.
http://www.e30m3project.com/e30m3per...t_transfer.htm
There's a reason track cars are LOW and wide.
robjh22
Sep 8, 2015 12:31 PM
