What's the story with the '14 gt track pack oil capacity?
Old Oct 20, 2015 | 08:34 PM
johnny_h55's Avatar
So buddy did my oil change and I brought him 8 quarts of 5W-50 motrocraft oil as per my owners manual and he said it wasn't enough. Then I started looking online and some people say the track pack and the boss 302's take 8.5 quarts of oil and not 8 quarts like the manual says. Some posts even say that some versions of the owners manual had an add-on page to mention this but if I pull up my owners manual online it doesn't talk about this nowhere:
http://www.fordservicecontent.com/Fo...US_02_2014.pdf
Old Oct 20, 2015 | 09:40 PM
Jazzman442's Avatar
8.5 quarts if you use the larger filler a little more. Expensive oil change since only 3 or 4 companies make the oil needed for this car.
Old Oct 21, 2015 | 06:26 AM
Brandon302's Avatar
+1 if the track pack comes with the oil cooler than it is 8.5 quarts and if you use the FL820S filter instead of the FL500S than you may want to put a tad more in.
Old Oct 21, 2015 | 06:27 AM
imeyers302's Avatar
Track Pack and Boss cars have an oil cooler which holds an additional half qt of oil. They also have different oil pans than regular 5.0s but its the cooler that adds the extra half qt.
Old Oct 21, 2015 | 07:08 AM
dmichaels's Avatar
Do we have the boss oil pan? A friend asked me last week and I wasn't sure
Old Oct 21, 2015 | 07:16 AM
5.M0NSTER's Avatar
I believe so. The capacity is the same as regular GT, but they have baffling to increase the protection value of oil reserve at high lat.
Old Oct 21, 2015 | 08:05 AM
johnny_h55's Avatar
So in the most crucial piece of information to a car's owner called the owners manual, ford couldn't get it right and specify this?
Old Oct 21, 2015 | 09:52 AM
5.M0NSTER's Avatar
Well, the oil pan is 8QT. If you add oil to the filter that's 1/4 QT and another 1/4QT in the oil cooler brings you to 8.5 max.
But are you able to get all of the oil out of the cooler? I doubt it. So if you put 8QT you will be between the 2 dots. If you put 8.5QT you'll be toward the top dot. Either way it's fine.
Old Oct 21, 2015 | 10:55 AM
kanine's Avatar
I have put only 8qts in the 2 oil changes I've done so far with no problems. The owner's manual on the 2014 says only 8 qts for the Track Packs, I think it said 8.5qts on the 13's.
Old Oct 21, 2015 | 11:44 AM
johnny_h55's Avatar
And where exactly does the oil level sit with 8 quarts after a fresh oil change on a track pack?
Old Oct 21, 2015 | 04:57 PM
johnny_h55's Avatar
The more i was thinking about this, shouldn't the oil contained in the filter already be taken into account by ford? If not they would of listed capacity with and without filter change like some other manufacturers?
Old Oct 21, 2015 | 05:04 PM
kanine's Avatar
It is almost near the full line on the dipstick. I try to check my oil level at least every month, and so far it's been about the same.
I'm going to be doing my 3rd oil change next month. I usually buy them in cases, so I usually get 2 cases and have extra oil left, just in case the engine burns oil or something.
Just do the oil change and then check, if not you can always add the extra 1/2 qt.
Old Oct 21, 2015 | 11:45 PM
rick0202's Avatar
The oil change spec are the same for the track pack as the boss. i have to tell the service department every time i go there. All they see is GT. One time i had to show the specs to them on my phone.
Old Oct 23, 2015 | 01:10 PM
5LHO's Avatar
You don't need 5W50 in these cars anyway so, you can save a buck or two. That's for track use. Good old 5W20 will be perfectly fine on the road. There is no diff between the track pack engines and the regular GTs, other than the oil cooler and Boss rad.
If you are using Motorcraft, the 5W20 actually shears down slower than the additive laden 5W50.
Old Oct 23, 2015 | 03:08 PM
dmichaels's Avatar
In a track environment the motorcraft 5w50 seems to shear to about 30wt after a couple hundred track miles. Per my oil analysis. Not impressed. It'll hold up just fine for street use tho. And I agree it's unnecessary for street only cars.
Old Oct 23, 2015 | 03:25 PM
Gabe's Avatar
It's in the Track Pack owner's manual supplement
Old Oct 23, 2015 | 05:41 PM
imeyers302's Avatar
Just did mine last week for the second time. I let it drain for a while. First filled with 8qts including pre oiling filter. Ran car for a few. Checked and oil was at bottom mark on dipstick. 1/2 qt more and it was dead on. Was exactly the same last time. If you have a track pack or boss, buy the 9th quart.
Yes. TP cars have the boss oil pan. Just one of the things they did not advertise.
Old Oct 23, 2015 | 07:10 PM
berzerk_1980's Avatar
Thanks for this. I never opened my owner's package and this supplement is one of the few documents you can't download from the owner's site.
tony2014mustang
Nov 2, 2015 05:17 PM
PJRManagement
Motorsports
Oct 26, 2015 06:34 PM
DerekShiekhi
Oct 22, 2015 05:30 PM
Oct 20, 2015 07:34 PM
