Sponsored by:
Sponsored by: CARiD
Performance Pack wheels and tires
Old Oct 18, 2015 | 06:47 PM
tony2014mustang's Avatar
I have a 2015 GT base with the standard 18in wheels and tires. I really want the 19in performance pack wheels and tires, and I think I can get them for cheap. Can I simply just make the swap, or is there anything else I HAVE to do?
Thanks everyone!
Old Oct 19, 2015 | 01:59 AM
YepItsGreen's Avatar
Think you have to have ford flash your car so the speedo will be right.
Old Oct 19, 2015 | 05:07 PM
I thought so, thanks!
Old Oct 19, 2015 | 08:09 PM
Crumpler's Avatar
Looks like a 1.5% rolling diameter difference. That's within the spec to just bolt on and go.
Old Oct 19, 2015 | 10:05 PM
Thanks Crumpler....very helpful!
Old Oct 20, 2015 | 06:54 AM
MRGTX's Avatar
You might need to reset the TPMS but even if so, I doubt that will be difficult. It may even be something you can do through the menus.
Share pics!
Old Oct 20, 2015 | 02:11 PM
Thanks....I think they're arriving Monday, maybe even Saturday. So, hopefully I will be able to get them installed asap!
Old Oct 21, 2015 | 08:21 PM
Am I going to need spacers? My fear is that I will be sitting will the tires off ready to go, and then find out that I needed spacers. I am installing them Saturday, so any help would be appreciated!
Old Oct 22, 2015 | 12:38 PM
dgc333's Avatar
Unless you are trying to push the wheels out there is no need for spacers.
Old Oct 22, 2015 | 02:54 PM
Oh ok, thanks!
Old Oct 23, 2015 | 06:23 AM
MRGTX's Avatar
^+1
Also, if you're planning on running spacers, be sure to schedule an appointment with a cranial injury specialist.
Old Oct 25, 2015 | 01:51 PM
I put my performance pack wheels and tires on yesterday, and what a difference it makes on her looks!! She feels nicer on the road as well - much more grip. Only issue I had was that I had to go out buy a new torque wrench because these puppies had to be torqued to 150lb/ft. Well not so bad, I got a new tool! I'm trying to post pics, but this site is not allowing me. Couldn't be happier.
Old Oct 25, 2015 | 07:08 PM
PJRManagement's Avatar
Currently a Corvette Owner!
Hi, just read this. Are you sure about the 150lb/ft...? I think 100lb/ft is the number for these cars.
Old Oct 25, 2015 | 07:14 PM
I thought it seemed high as well, but it's in that manual.
Old Nov 2, 2015 | 04:34 PM
Bert's Avatar
hmmmmmmm . . . . I'm betting that is a typo; can't think of why the torque would be higher . . . . except I did hear that the studs are different size and thread from prior years . . . . finer pitch thread needs higher torque to get same preload
Old Nov 2, 2015 | 05:02 PM
When I asked the guy at Ford, he told to follow the manual....so I did.
Old Nov 2, 2015 | 05:17 PM
dgc333's Avatar
You have that backwards, finer thread pitch requires less torque to get the same preload.
Finer thread pitch fasteners are stronger than the same size course thread due to the larger tensile area. They are also less likely to loosen due to vibration because of the shallower helix angle in the thread.
Al Thor
Feb 10, 2016 10:14 AM
colt breaker
Nov 13, 2015 01:09 PM
m05fastbackGT
Oct 16, 2015 10:19 PM
Oct 15, 2015 08:00 AM
