What's the story with the '14 gt track pack oil capacity?
So buddy did my oil change and I brought him 8 quarts of 5W-50 motrocraft oil as per my owners manual and he said it wasn't enough. Then I started looking online and some people say the track pack and the boss 302's take 8.5 quarts of oil and not 8 quarts like the manual says. Some posts even say that some versions of the owners manual had an add-on page to mention this but if I pull up my owners manual online it doesn't talk about this nowhere:
http://www.fordservicecontent.com/Fo...US_02_2014.pdf |
8.5 quarts if you use the larger filler a little more. Expensive oil change since only 3 or 4 companies make the oil needed for this car.
+1 if the track pack comes with the oil cooler than it is 8.5 quarts and if you use the FL820S filter instead of the FL500S than you may want to put a tad more in.
Track Pack and Boss cars have an oil cooler which holds an additional half qt of oil. They also have different oil pans than regular 5.0s but its the cooler that adds the extra half qt.
Originally Posted by imeyers302
(Post 6950848)
I believe so. The capacity is the same as regular GT, but they have baffling to increase the protection value of oil reserve at high lat.
So in the most crucial piece of information to a car's owner called the owners manual, ford couldn't get it right and specify this?
Well, the oil pan is 8QT. If you add oil to the filter that's 1/4 QT and another 1/4QT in the oil cooler brings you to 8.5 max.
But are you able to get all of the oil out of the cooler? I doubt it. So if you put 8QT you will be between the 2 dots. If you put 8.5QT you'll be toward the top dot. Either way it's fine. |
I have put only 8qts in the 2 oil changes I've done so far with no problems. The owner's manual on the 2014 says only 8 qts for the Track Packs, I think it said 8.5qts on the 13's.
Originally Posted by kanine
(Post 6950885)
And where exactly does the oil level sit with 8 quarts after a fresh oil change on a track pack? |
Originally Posted by 5.M0NSTER
(Post 6950880)
Originally Posted by johnny_h55
(Post 6950890)
I'm going to be doing my 3rd oil change next month. I usually buy them in cases, so I usually get 2 cases and have extra oil left, just in case the engine burns oil or something. Just do the oil change and then check, if not you can always add the extra 1/2 qt. |
The oil change spec are the same for the track pack as the boss. i have to tell the service department every time i go there. All they see is GT. One time i had to show the specs to them on my phone.
You don't need 5W50 in these cars anyway so, you can save a buck or two. That's for track use. Good old 5W20 will be perfectly fine on the road. There is no diff between the track pack engines and the regular GTs, other than the oil cooler and Boss rad.
If you are using Motorcraft, the 5W20 actually shears down slower than the additive laden 5W50. |
Originally Posted by 5LHO
(Post 6951162)
(Post 6950865)
https://themustangsource.com/forums/...n-untitled.jpg |
(Post 6950890)
Originally Posted by dmichaels
(Post 6950854)
Do we have the boss oil pan? A friend asked me last week and I wasn't sure
Originally Posted by Gabe
(Post 6951183)
It's in the Track Pack owner's manual supplement
