What is that noise???
Old Dec 16, 2013 | 10:11 PM
Michael Broadway's Avatar
I heard it today for the first time. I had been driving for 20 minutes or so, the engine was nicely warmed up to operating temperature. I took off from the light. There was a nice downhill, clear stretch ahead of me. Shifted into 2nd gear, then into 3rd, and then I punched it. That's when I heard it. My wife even said, "What's that noise?"
The best way to describe it is that it was a bubbling, burbling sound. It was coming from under the hood and seemed to be located on the right side. It almost sounded like an exhaust noise, but not nearly as loud. I let off on the gas and slowed down, then punched it again, and it returned like before.
Five miles later, I decided to try it again, and the sound didn't repeat itself.
Has anyone experienced this strange noise? If so, do you have any idea what it might be? My car is a 2012 GT with the MT82 and totally stock with 13,500 miles on the clock.
Thanks for any input.
Old Dec 16, 2013 | 11:17 PM
Twin Turbo's Avatar
Sure it wasn't "pinking", which is more of a tinkling sound? That's pre-ignition, often caused by poor gas.
Old Dec 18, 2013 | 01:35 AM
taneshaleo's Avatar
Noise may be coming because of the poor or bad gas.
Old Dec 18, 2013 | 01:43 PM
FordService's Avatar
Originally Posted by Michael Broadway
I heard it today for the first time. I had been driving for 20 minutes or so, the engine was nicely warmed up to operating temperature. I took off from the light. There was a nice downhill, clear stretch ahead of me. Shifted into 2nd gear, then into 3rd, and then I punched it. That's when I heard it. My wife even said, "What's that noise?"...
Hey Michael Broadway,
You should have your dealer check it out. Your service manager is in the best position to let you know if there is any work needed, coverages, recalls, or assistance available. Let me know what they say.
Deysha
Old Dec 20, 2013 | 01:47 AM
I hadn't considered the fuel possibility. I only have about 1/4 of a tank in there, so that might be the cause. Does Ford recommend any fuel additives to take any water out of the gas?
And thanks, Deysha. If it doesn't happen any more for a while, I'll mention it at my next oil change. If it does happen again, I'll make a special trip and see what they say.
Old Dec 20, 2013 | 08:04 AM
No problem. Just keep me posted.
Deysha
Old Dec 20, 2013 | 08:36 AM
slostang's Avatar
It's a stock car, even if he put 87 in the car it still shouldn't PING, the car has widebands that trim fuel, knock sensors that dump timing. I don't see fuel being the issue here.
Take it to ford, or just put the car back under a load and hit it and see what you get.
Old Dec 20, 2013 | 08:45 AM
Moustang's Avatar
There are lots of fuel stabilizers on the market. Probably the most common name is Sta-bil.
Old Dec 20, 2013 | 10:38 PM
southcarolina12's Avatar
sounds like the exhaust note but not near as loud and is coming from under the hood? sounds like youre hearing the air intake to me. i have a aftermarket intake and my intake note is way louder than the exhaust inside the cab when i get on it but only at certain rpm's.
Old Dec 20, 2013 | 11:10 PM
I don't know that Sta-bil is as good after moisture has already entered the system.
I think he needs Heet to remove moisture after the fact.
Or just add a tank of fresh fuel and drive.
HEET® brand is the #1 Selling Gas-Line Antifreeze & Water Remover. It removes water from the fuel system to prevent gas-line freeze-up and harmful rust and corrosion. ISO-HEET® brand is the #1 Selling Premium Fuel-line Antifreeze, Water Remover & Injector Cleaner. It absorbs 5 times more water than regular gas-line antifreeze, while it cleans fuel injectors and carburetors. It’s designed for use year-round in ALL 2-cycle and 4-cycle gasoline engines and diesel engines.
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Mr. V
Dec 24, 2016 02:57 PM
ricky1728
Feb 11, 2016 07:25 PM
Rando
Sep 30, 2015 12:28 PM
