What are the benefits from doing an X-pipe?
Old Mar 27, 2011 | 01:39 PM
2011_STANG_GT's Avatar
So I'm about to buy either the Roush or Bassani axle backs. But that doesn't give any HP. An X-pipe would? also how much louder would it make the car over just the reg AB's? Is a tune required for a x-pipe? And lastly what is the best x-pipe?
Old Mar 27, 2011 | 01:42 PM
x pipe will give you a couple hp axle backs give you a few more than the x pipe would.
Old Mar 27, 2011 | 01:43 PM
vmilax2007's Avatar
Do yourself a favor and pull the trigger on a set of Roush's. They sound amazing man!
Old Mar 27, 2011 | 01:54 PM
Jott's Avatar
Don't quote me, but i recall hearing from more than one source that you may even lose power using some x-pipes, compared to the stock H.
Old Mar 27, 2011 | 03:22 PM
Joe_in_Naples's Avatar
Another vote for the Roush A/B's. You will love them!! If you end up going with a off road X pipe, just be warned that your car will be very loud along with the Roush system. Go on youtube and look for some videos, there should be some samples to check out.
Old Mar 27, 2011 | 03:49 PM
QuadCammer5.0's Avatar
You will need a tune if you delete the stock cats. But if you go catback you shouldn't need one.
Old Mar 27, 2011 | 05:22 PM
Five Oh Brian's Avatar
I ran SLP's catted X-Pipe on my supercharged '07 GT. My ET's in the 1/4 mile improved by 2 tenths as the factory exhaust was a bit restrictive with the blower on the car. Naturally aspirated cars might not see as much improvement.
Old Mar 27, 2011 | 11:02 PM
DaSFGiants4Life's Avatar
I'd say youd get a lil more HP. but the sound will be much louder.
Sent from my iPhone using TMS Forum
Old Mar 27, 2011 | 11:11 PM
Overboost's Avatar
I have the Corsa X-pipe with Corsa Extreme A/Bs. Without it (the X-pipe), the sound was raspy and somewhat obnoxious. Once installed, the sound is greatly improved.
When I dynoed my car with 87 and no other mods, the X-pipe & A/B combo netted me 10-12hp over what people expect to see with the stock system. IIRC the X-pipe allows for better flow than the H-pipe design.
Old Mar 27, 2011 | 11:26 PM
VENOMOUS ONE's Avatar
I told u get sell the gt for a cobra solve all problems. Bassani ss xpipe. Yes u need a tune ur taking the cat out. And loosen 2 o2s
Old Mar 27, 2011 | 11:27 PM
Not tru
Old Mar 28, 2011 | 12:09 PM
Ivan 5.0's Avatar
From what I've read - you can expect a few horsepower from replacing the factory h-pipe with an aftermarket x-pipe (mind you, you can't really feel a 2-5WHP difference). Much larger gains are to be found by removing the cats though - so if you're going for power, an off-road xpipe would be the way to go. This will, however, require a tune. A tune isn't needed for anything cat-back.
Old Mar 28, 2011 | 12:53 PM
Bert's Avatar
Originally Posted by Ivan 5.0
. . . . Much larger gains are to be found by removing the cats though - so if you're going for power, an off-road xpipe would be the way to go. This will, however, require a tune. . . ..
also remember "off road" means "not legal for use on the road"
Old Mar 28, 2011 | 01:04 PM
Boomer's Avatar
Which in turn also should not be taken literally...
Old Apr 4, 2011 | 02:36 PM
Xpipe all the way. Free up them cats an let the hp flow.
Old Apr 4, 2011 | 07:29 PM
unas2k5's Avatar
Aren't high flow cats just as good?
Old Apr 5, 2011 | 03:27 PM
SurfnSoCal's Avatar
No, that's like saying using a rubber is just as good as without.
Take 'em off!
Old Apr 5, 2011 | 04:08 PM
zcgstang's Avatar
Im on the same position. I have pype bombs and want the o/r x but im worried It will be stupid loud
Old Apr 6, 2011 | 07:51 AM
JScottGT's Avatar
It shouldn't increase the exhaust volume any with an X-pipe. It will just change the tone some. An X-pipe usually gives it a little more of an "exotic" sound, where the "H" makes the sound deeper. The old adage of use on Mustangs has always been use an H-pipe with chambered mufflers, and an X-pipe with straight-thru mufflers. Those combinations yield the best overall sound. Exhaust sound is a very personal thing though... what sounds good to some, will sound like crap to others.
Old Apr 17, 2011 | 07:15 PM
Xpipe has no cats and made my cobra twice as loud.
