VMP TVS Stage 2 Supercharger install - 11gt
#41
You can go to the link and read the instructions to see what is involved. Not a hard install and you are going to ask yourself why you didn't install one sooner.
http://vmp-tvs.com/justin/instructions/
I have 3.55's in my auto. Any updates? How is it driving? Do you get immediate power compared to stock? Just waiting for Labor day weekend so I can get mine installed. Saving up a little more too. Was the gauge pretty easy to install (getting through to the engine) Did you have to take much apart?
Thanks for the info
Thanks for the info
#42
Thanks for the info
Thanks for the info
Dude its a supercharger lol, foot to the floor, ***** to the walls. Even for an auto its insane to drive, but insane in a good way.
When coasting around town, drives like a normal car, no different really, when you get on the gas its a different story all together.
The gauge is easy to install. The roush one has 4 different electrical connectors. the red for 12v power which i ran to the fuse box located in the passenger side footwell. Used a 10amp mini inline fuse thingy that i got at a local auto parts store. There is a white wire for the white light which i tied into the 12v red so when the car accessory is on its a white gauge. The blue i tied into the auto lights which is still finicky which i have to figure out. Ground just found a ground. As far as the vacuum line goes, its easy to run, there is a hole that is in the firewall that will be exposed when you remove the sound tube for the intake. I ran it through there, along the firewall to the port on the fuel charge assembly. its a 1/8" fitting MPT with a 1/8" barb.
#45
No lol, mainly because the tires i have on right now are almost bald and terrible to begin with. If i floor it from a stop, i get spin then major wheel hop. So LCA's in the near future. Maybe when i order my hood struts. I'm running 285's in the rear right now but the next tire im going wider. 305 or 315.
#46
Yeah I did the boss 302 lca's on mine you might want to do uppers too. That is crazy the power you must be getting I drove the roush stage 3 at the dealer and it did not break loose and really was not impressive for the 62k price tag. I just hope when i get the vmp kit I can get the tires to hook up I was looking at the michelin super sport
#47
I've wanted to make sure everything is working out before i do, i have to do redo a data log for the tuner but so far he said it looks good.
#48
side comment.... can anyone tell me what it typically runs you to get your vehicle dyno'd in the US?
I found a shop here in Pickering Ontario that charges $200 an hour. it doesn't seem unreasonable...
#49
here in houston,tx. we have club events which does 20 - 30 cars together and we could get three pull done for 40.. but if u take ur car for one on one session we would have to pay north of 100 bucks...
#50
#51
http://mustangforums.com/forum/5-0l-...e-problem.html
