use 0W-20 synthetic oil in the winter?
Old Jan 6, 2012 | 09:24 AM
BlackMamba03's Avatar
These threads are hilarious.
Old Jan 6, 2012 | 09:29 AM
Originally Posted by jlmounce
Not to mention you wouldn't see 5w50 recommended for the Boss which uses the same tiVCT mechanisms.
Boom. Knowledge.
Old Jan 6, 2012 | 09:36 AM
^ hahaha.... tell me about it, Jamie...
Old Jan 6, 2012 | 02:07 PM
wonger's Avatar
Originally Posted by BlackMamba03
Boom. Knowledge.
Boom. The Boss also has blocked off oil squirters doesn't need to stick to a thinner oil to make it though those when up to temp.
Knowledge.
Old Jan 6, 2012 | 02:21 PM
montreal ponies's Avatar
Knowledge.
^^^^^^he's got a valid point there folks.
Old Jan 6, 2012 | 02:23 PM
Ford changed it's recommendation in the 4.6l mustangs from 5w30 to 5w20 in 2001 with no internal changes to those motors.
From the 1st printing US owner's guide. It's even bold in the owner's guide itself.
To protect your engine and engine’s warranty, use Motorcraft SAE
5W-20 or an equivalent SAE 5W-20 oil meeting Ford specification
WSS-M2C930-A. SAE 5W-20 oil provides optimum fuel economy and
durability performance meeting all requirements for your
vehicle’s engine. Refer to Maintenance product specifications and
capacities later in this chapter for more information.
Since you conveniently overlooked my original comment that stated 5w20 is fine for the average user, I'll say it again. 5w20 was selected for fuel economy reasons, but still provides enough protection for the average user.
It's not because of the design of the engine. If the tolerances were such in the bearings or the tiVCT didn't work properly with heavier weight oils, it would specifically state that. not to mention you wouldn't see 5w50 recommended for the Boss which uses the same tiVCT mechanisms.
Boom. Knowledge.
I didn't overlook your statement. But your original comment clearly infers - like the other couple of 'oil experts' - that the only reason Ford uses 5w-20 is for CAFE - to the detriment of longevity. Which is completely false. As the highlighted portion of your quote above states.
So why no comment about Chrysler and other manufacturers? If the trick worked for Ford to eek out better fleet mileage, other manufacturers would have piled on.
The VCT in the 4.6 and the TiVCT in the 5.0 are not the same. The VCT is completely hydraulic action. TiVCT is partial hydraulic and partial 'cam torque actuated'. But now you're mixing apples and oranges.
The Coyote's TiVCT benefits from cam torque actuation. Instead of high-pressure oil energizing the cam phasers, CTA uses the valvespring energy torquing through the camshafts. At certain periods of cam rotation, valvespring pressure tries to advance the cams, and retard them at other points. This snappy back and forth energy is traditionally dissipated uselessly into the timing chains, but with CTA it's used to power the cam phasers. Engine oil is still used to fill the cam phaser chambers and thus hold the new cam position, but not physically advance or retard the cam-that work is done strictly by cam torque from the valvesprings. As such, there is no hardware in CTA. It is only a strategy.
In fact, in exchange for some crafty thinking and hard-won computer software, there are less hardware and cylinder-head-design headaches with CTA. The control mechanism for shuttling oil in and out of the phasers is a simple solenoid because the three-way shuttle valve is not required. High-pressure oil is also not needed, so the engine's oil pump can be downsized and horsepower saved. Nor are dedicated oil passages to the phasers required. Instead, the Coyote's TiVCT with CTA system siphons off bleed oil from the nearest cam journal.
Read more: http://www.mustang50magazine.com/tec...#ixzz1iiX0nv4P
Boom. Knowledge. And practical application.
Old Jan 6, 2012 | 02:24 PM
Motorcraft 5W20 full synthetic and live with a clear conscience.
Old Jan 6, 2012 | 02:54 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
The VCT in the 4.6 and the TiVCT in the 5.0 are not the same. The VCT is completely hydraulic action. TiVCT is partial hydraulic and partial 'cam torque actuated'. But now your mixing apples and oranges.
Bravo! Bravo!
Old Jan 6, 2012 | 03:27 PM
Knowledge.
I'll counter with the fact that there are guys running 10w30 in their 5.0's without a problem.
Old Jan 6, 2012 | 03:30 PM
Bear Eats King...
Bear ****s Bone
Yet...
Old Jan 6, 2012 | 04:13 PM
wonger's Avatar
My car that I'm driving has 5w-20 synthetic. My car is running fine too. Too much talk and worry here about this. What did you decide to put in your car?
Old Jan 6, 2012 | 04:21 PM
Old Jan 10, 2012 | 10:31 AM
Bert's Avatar
Interesting conversation everyone, thanks for the input . . . though I got a little more than I bargained for!
I ended up using 5 quarts of 5W-20 plus 1 quart of 0W-20 Mobil 1, since I had a 5-quart jug plus some quarts of 0W-20 laying around that I use for my wife's Camry. I don't think the 1 quart of 0W-20 is going to make any significant difference, but figured it can't hurt in the winter. It is cold here now so I had a Ford dealer do the oil change (car was in for some minor warranty work before it runs out) and they didn't raise any objections to the 1 quart of 0W-20.
Interestingly enough, and at the risk of resurrecting this dead horse, Toyota recommends 0W-20 for the Camry (and other cars I suspect) for "maximum fuel efficiency" and they don't seem to have any longevity issues . . .
Old Jan 10, 2012 | 10:51 AM
Bucko's Avatar
Chest beating class 101.....these oil, oil filter, air filter, exhaust, and tuner posts will remain far after the cockroaches die....
Old Jan 12, 2012 | 04:16 PM
Big Poppa's Avatar
For what it's worth, I changed my oil last week and put in 5W30 for a tad bit extra protection. The reason I did this because I routinely drive 80 - 120 MPH for long distances, with spurts up to 130-140. I don't know how Ford tested their engines, but I imagine a slightly heavier oil wouldn't hurt. The Boss has pretty much the same engine and it uses 5W50 so I figure going to 30 won't hurt. Now, if 5W30 causes me some engine damage then IMHO this engine wasn't worth a nickel to begin with and was going to fail regardless.
Old Jan 12, 2012 | 05:20 PM
130-140 mph spurts?????? Routinely????
Old Jan 13, 2012 | 04:11 PM
Big Poppa's Avatar
Don't know exactly what your question is, but where I live in a region where many roads and highways have no speed limits. Where there are speed limits they are seldom enforced. If you want to know the truth 130-140 around here is not very fast. People pass me going so fast I think the are going the other way.
Old Jan 13, 2012 | 04:27 PM
2012GTCS's Avatar
Hahahahaha. That is great
Old Jan 14, 2012 | 06:49 AM
I just didn't know where you could "routinely" and safely drive at those speeds. Please be careful.
Old Jan 16, 2012 | 04:29 AM
  #40
Big Poppa's Avatar
Like I was saying, if 5W30 causes me some oil related engine damage then IMHO this engine wasn't worth a nickel to begin with and is going to fail regardless of what oil you put in it.
dave07
Oct 8, 2015 03:14 PM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
