Trunk won't open!
Old Jun 9, 2013 | 11:22 AM
rhsab's Avatar
Angry Trunk won't open!
Took my car out today and opened the trunk with my remote, closed trunk fully and went to open it again and remote would not open it and interior trunk button doesn't work either. both remotes did not work. tried disconnecting battery to reset and that did not work. Is there something else I can do before I take it to dealer. Its a 2012 GT. "Trunk ajar" light is on also.
Old Jun 9, 2013 | 11:49 AM
Ajcruz1's Avatar
You may have something stuck in where it latches. Try folding down your back seats and going in to your trunk and try pulling the emergency release cable. it has a neon (yellow/greenish) plastic T attached to it, pull that and hopefully that opens your trunk.
Old Jun 9, 2013 | 07:23 PM
Ajcruz1's Avatar
Did you get it open?
Old Jun 9, 2013 | 07:55 PM
hawkeye18's Avatar
I think he got stuck in the trunk and died.
Old Jun 9, 2013 | 08:20 PM
tukatz's Avatar
No, no, no!!! If you are IN the trunk you can get it open and get out. But if you are OUTSIDE the trunk you can't get it open to get in. Seems like a design flaw.
Old Jun 9, 2013 | 09:54 PM
Gabe's Avatar
My '13 has had some trunk issues also. This morning I made a U-turn and as I'm making it the Trunk Ajar light popped on. I stopped, the trunk was closed.
I popped it open with the button on the console, pushed down on the latch button down next to the striker, and closed it.
Light went out and no more issues for the rest of today.
I'd love to see if other people are having a repair done for these issues ...
Old Jun 10, 2013 | 06:09 AM
Ronin38's Avatar
That's what you get for doing U-turns on 2 wheels...
At least your defroster vents didn't pop out.
Old Jun 10, 2013 | 06:27 AM
Rando's Avatar
I use my trunk at least 2 times every day. Never had a single issue
Old Jul 2, 2013 | 11:54 PM
Michael Broadway's Avatar
I have had the "Trunk Ajar" warning come on a couple of times for no apparent reason. It sounds like it may be some type of inherent issue that needs a TSB since so many people seem to be having it.
Old Jul 3, 2013 | 11:36 AM
TheReaper's Avatar
When my trunk won't open I use one of these.
Old Jul 3, 2013 | 11:55 AM
wheelman's Avatar
Your trunk monkey is out of order.
Old Jul 3, 2013 | 03:08 PM
wanted33's Avatar
I hope he saw that little running man on the little yellow thingy. If not how could he know?????????
Old Sep 4, 2015 | 04:10 PM
nguyenfamily's Avatar
So I have a 2014 Mustang and my trunk won't open unless I use the emergency release. The trunk won't open from the key or the inside of the car. What's the problem?
Old Sep 4, 2015 | 04:13 PM
Please help
Old Sep 4, 2015 | 07:16 PM
Gabe's Avatar
Please help
2014 = warranty, if under 36k miles.
Check with the dealer yet?
Old Dec 18, 2017 | 11:14 PM
14v6impactblue's Avatar
Ok so I had the exact same problem. I read this post about 3 weeks ago. What I did to fix the problem was pull back the interior material covering the trunk actuator. I pulled the quick connect out and could tell pretty fast it was not locked in well. Pushed the connector back in and it works like it is supposed to now. I guess it worked it's way out. Hope that helps.
Old Dec 22, 2017 | 05:23 PM
Alwyn Dowell's Avatar
Trunk problem on 2016 mustangs
The answers is a wire on your trunk lid there a wire that runs to the latch if it pulled too tight it will break and cause it not to work
Just had mine fix and I ask what cause the problem and this is what I was told luckily it was still under warranty
Old Jan 5, 2018 | 10:04 AM
dbpbandit's Avatar
My trunk makes a loud ratcheting noise when I hit the button. Sometimes it's a short burst, sometimes is a lot longer but it only seems to do it when it's really cold outside. I figure I'll be needing to replace that mechanism in the near future. Is there an actual name for the unit? Also, is this a dealer only item or are there other suppliers? Sorry if this is hijacking the thread but since the OP hasn't responded (I hope he's not stuck in his trunk) I figured it would be OK. Thanks.
Gigantor
May 11, 2023 07:31 PM
kponypower
Jun 17, 2020 07:17 AM
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 30, 2015 07:02 PM
