trans fluid
i wouldnt use it. it doesnt withstand heat as good and it ends up as gumps inside the transmission if you dont change it more frequently. if you want firmer shifts get a tune and just take it off before you take it in for warranty.
they probably could. i know gm can but not sure about ford. they dont normally check to see if its been flashed i know that tho. i had to get my transmission replaced and i had a tune on mine at the time. didnt have a single problem.
