"Tire Pressure Sensor Fault" Indication
Old Oct 22, 2013 | 01:50 PM
CR_Stang's Avatar
Hey guys maybe someone can help out here for a sec...I got new 20" wheels installed on my 2013 GT with new TPMS sensors and noticed that if I run for a certain period of time at +70mph or more, I will get the indication displayed on my dashboard.
First time I got it I read it wrong and believed I had a flat tire, but it was a sensor fault. Now, if I leave my car parked for a few hours, everything will go back to normal and will stay like that if I am just driving around town, until I hit a freeway again and get some speed going.
Any ideas?
Old Oct 22, 2013 | 03:22 PM
TheDivaDanielle's Avatar
not using genuine ford sensors?
Old Oct 22, 2013 | 07:15 PM
HizliBullet's Avatar
are those the orotek 0315 mhz sensors from AM?
Old Oct 23, 2013 | 07:04 AM
5.M0NSTER's Avatar
Sounds like at speed the RKE module looses the signal from tire pressure sensors, and flags them as faulty. When you slow down the RKE can pick up the signal again. It could be something wrong with the antenna connection on one of the sensors, or even the wheel affecting the signal.
Have you read the DTC codes? Is it one sensor consistently?
Old Oct 23, 2013 | 12:44 PM
Ltngdrvr's Avatar
Yeah, just sounds like a bad sensor.
Had one show that on my F250 and it was replaced under warranty.
Old Oct 23, 2013 | 03:01 PM
CR_Stang's Avatar
I got OEM sensors part 9L3T-1A180-BB (http://www.ebay.com/itm/151064322657...84.m1439.l2649). Should I get another set to try and see if there is any change?
Old Oct 23, 2013 | 03:04 PM
CR_Stang's Avatar
i will take it to the dealer to see if they can tell me if it is always the same sensor
Old Oct 23, 2013 | 08:39 PM
5.M0NSTER's Avatar
If your car is still under warranty, that would be a good idea. If not you can take it to a local AutoZone or similar, and they will read your trouble codes free of charge.
Good luck getting this issue resolved. Keep us posted on the outcome.
Old Oct 24, 2013 | 01:54 PM
kylerohde's Avatar
With aftermarket wheels, the warranty doesn't apply. And this isn't a check engine light, it's a TPMS warning light so not sure what scanning for a code at AutoZone is going to do. You've got a bad sensor.
Old Oct 24, 2013 | 02:41 PM
5.M0NSTER's Avatar
Any system failure warning light which comes on the dash is attached to a DTC. After the fault goes away the light is cleared, and the fault code goes to history. If there is a bad TPMS sensor there should be a record of it in the vehicle's EEPROM. The reason for this is warranty cost. If you come in with a faulted TPMS system, and it will tell you which sensor is bad, so you don't have to replace all 4.
Old Oct 24, 2013 | 03:35 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Autozone cant diag tpms... just sayin. They can get p codes tops. Which is powertrain only. No b, c, t, or u codes can be pulled by what autozone uses.
Also eeprom is pre odb2. It is now stored in the kam (keep alive memory) and to top it off the tpms module stores all tpms codes. Pcm doesnt store any tpms faults. The scanners that autozone use are generic quick scanners that only have the ability to comunicate with the pcm.
Old Oct 24, 2013 | 03:57 PM
Lime GT's Avatar
Any ideas?
Did you check your air pressure in the tires after a 70 mph+ run? TPMS will also trigger if air pressure is too high. Are you inflating the tires to the decals spec on the door pillar, correct, or to the maximum cold inflation written on the tire, wrong?
Old Oct 24, 2013 | 03:59 PM
Bear Eats King...
Bear ****s Bone
He is getting a fault. Not a pressure issue. Its a signal/sensor issue
Old Oct 25, 2013 | 06:49 AM
5.M0NSTER's Avatar
KAM is a form of EEPROM since that's the only way to store data after the memory looses electrical power.
But I think you have a point on the communication with the Remote Keyless Entry system (which receives TPMS data). Generic tools probably won't work, as you most likely need a CAN database specific to the vehicle to interpret all the messages going across the bus. So good point there.
Sounds like to read the codes he may have to go to the dealer. Which is $$$
Old Oct 25, 2013 | 07:27 AM
sai's Avatar
sai
I just had my rtr wheels and cooper zeon tires installed with ford oem tpms bought from eBay, I don't see any tpms warning on my cluster, I never even synced them, just installed and driving.
http://bit.ly/H6vrDq
Old Oct 25, 2013 | 09:53 AM
Bear Eats King...
Bear ****s Bone
Most shops have a fancy enough scanner to read all the modules on a car. Bit I would see if the dealer would be nice enough to check it under warranty. Some dealers are nice about things
Old Oct 25, 2013 | 12:22 PM
Horspla's Avatar
Not to hi-jack this thread, but if tires are mounted without pressure monitors and the monitors were put in the pressurized canister and left in the trunk, would that trick the system so the computer wouldn’t give a low tire warning or monitor fault?
Thanks,
John
Old Oct 25, 2013 | 01:19 PM
PonyOx's Avatar
Google or search here for "TPMS Pipe Bomb" for details.
Old Oct 25, 2013 | 01:31 PM
5.M0NSTER's Avatar
Thanks,
John
Almost, but not quite.
The sensors are motion activated. When stationary they transmit once every 60 minutes (or something along these lines). But once the vehicle starts moving they broadcast the signal once every 30s (more or less). The receiving module will then monitor the receptions, and if it doesn't get any RF packets from a particular sensor in few minutes of vehicle speed being over ~15mph, it will set a fault. Much like what is happening to OP.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
BigHoss
Sep 21, 2015 10:03 AM
oldnjguy
Sep 10, 2015 02:39 PM
haitham
Sep 8, 2015 12:52 PM
Sep 8, 2015 10:45 AM
