For those running Lethal OR X pipe...
Old Nov 1, 2010 | 08:00 PM
2011GTCS's Avatar
What axle backs are you running?
I've got the Flowmaster hushpowers, and they have a horrible drone between 1800 and 2200.
I like the sound otherwise, but I can't take the drone, so I need your help!!!
Old Nov 1, 2010 | 08:08 PM
Ltngdrvr's Avatar
Still have the oem mid mufflers on it?
Old Nov 1, 2010 | 09:10 PM
factory fast's Avatar
Drone really??? I have them and i haven't noticed anything at all. Maybe you are in too high of a gear for the speed you are going.
Old Nov 1, 2010 | 09:42 PM
Ltngdrvr's Avatar
Yeah, but does your car still have the cats on it? His doesn't.
Old Nov 2, 2010 | 04:40 AM
Overboost's Avatar
Why does everyone call the X-pipe an off-road one when you don't eliminate any cats whatsoever?
Old Nov 2, 2010 | 07:38 AM
m4reapr's Avatar
Dude, do some homework
lethal O/R x-pipe = NO CATS
Old Nov 2, 2010 | 07:56 AM
rodmoe's Avatar
Ewww then you get that SMELL ???? or can you tune that out? So i take it a other than the cats gone a X pipe flows a lot better than a H pipe ?
Old Nov 2, 2010 | 08:05 AM
Overboost's Avatar
Dude, I did my homework, and crawled under the car. Didn't realize the cats could be removed without cutting the header portion of the exhaust.
The Corsa one on my car doesn't remove those, and is not an off-road. Slow your role there skippy.
Old Nov 2, 2010 | 08:09 AM
QuadCammer5.0's Avatar
If you get a cat back, it leaves the cats on. If you get an axleback, then get an offroad it eliminates the cats.
Old Nov 2, 2010 | 10:20 AM
2011GTCS's Avatar
If you mean the resonaters, then yes.
Old Nov 2, 2010 | 10:27 AM
2011GTCS's Avatar
It is in any gear, between 1800 and 2200 rpm, bad enough to rattle your teeth under heavy load (like going up a hill).
Unfortunately, that is right where my motor runs at highway speeds, so it is REALLY annoying...
I have factory headers, no cats, Lethal Off Road 3" X pipe, stock midpipes and resonators, and HushPower axle-backs.
I have a convertible, I'm not sure if that makes a difference or not...
If anybody out there has a similar setup with different mufflers and does not have the drone, please let me know what you have so I can fix this problem.
Thanks for your help!!!
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 30, 2015 07:02 PM
