Spring choices
Old Feb 2, 2011 | 09:25 PM
2010GT's Avatar
Spring choices
Looking for basically a 1.5 inch drop all around.Good ride quality, and a little handling improvement. Would like to hear everyones opinions on Ford , Steeda, BMR, H&R, Eibach springs etc. And why you would choose one brand over the other . Thanks
Old Feb 3, 2011 | 11:21 AM
sam strano's Avatar
Ahhh, it's not that simple. First, I'd rule out BMR because they aren't for anything but looks, they are lower and no stiffer than stock. As for the others, they all have various options. I 95% of the time use a particular version of Steeda Sport springs which are made by Hypercoil, super high quality, lightweight, great balance, and best of all a great riding set of lowering springs. I also sell Eibach and H&R (and Ford Racing are Eibach springs they are not anything special).
Bottom line it comes down to quality, ride and what you feel works best. Having the chance to be in a lot of cars on various setups and rates I get a better sense of that than someone who goes from stock to one set only.
My preference above all are linear rate Steeda Sports, then Ultralites, then some H&R's then Eibach. Note that I don't ever want folks on slammed springs of any brand, no Steeda Extreme Sport, Eibach Sportlines, or H&R Super Sports, if I can help it. Those are more looks than anything.
Old Feb 3, 2011 | 12:22 PM
2010GT's Avatar
Thank you Sam . I appreciate your thorough response . I am at work right now but I want the steeda ultra lite springs so I will call you when I get home and place my order thanks.
Old Feb 3, 2011 | 01:10 PM
2011 GT's Avatar
I'm am almost certain that you will LOVE the Steed Ultralites. That's what I've decided on and these springs have not only improved the looks and stance of the vehicle, but have certainly improved the handling, without the loss of ride quality!
If I was given the choice again, I wouldn't change a thing and would go with Steeda over and over again. Hands down!
Old Feb 3, 2011 | 01:15 PM
ssimaniac's Avatar
So just the Ultralites and nothing else? You left everything else stock? Mounts etc.?
I think I want to do that rout as well. Does it eliminate the highway bounce the brembo comes with? lol
Old Feb 3, 2011 | 01:26 PM
2011 GT's Avatar
Everything is stock, except of the Steeda Adjustable Panhard Bar. In order to properly allign the car when lowering, I truly felt that this was a necessary accessory.
Old Feb 4, 2011 | 10:27 AM
kws6000's Avatar
Sam,which lowering springs would have the smoothest ride?
Old Feb 4, 2011 | 10:21 PM
2011GT/CS's Avatar
Ford racing is $180 for all of it, and your supporting ford. How could you go with anything else.
Old Feb 7, 2011 | 09:36 AM
The Sheriff's Avatar
I hadn't heard about a highway bounce with the Brembo package, how bad is it?
Old Feb 10, 2011 | 10:41 PM
brycerichert's Avatar
I felt it... it was shattering my head... the supsension frequency is TERRIBLE from the factory. I can't see how people can drive it stock.
Best thing someone can do is swap out the springs and dampers the minute it's off the lot.
Old Feb 11, 2011 | 08:27 AM
erickburke's Avatar
When I was researching this I had a tough time finding any negative feedback on the Steeda Ultr-Lite springs. Handling, looks & ride are all there...
Old Feb 11, 2011 | 08:31 AM
m4a1mustang's Avatar
I bought my car in St. Louis, MO and drove 1,000 miles back to Washington, DC so I know ALL about the suspension bounce! It is B-A-D BAD!
The 370Z I drove to STL felt like a Rolls Royce by comparison.
Old Feb 11, 2011 | 11:19 AM
because there is better out there with life time warranty.
Old Feb 11, 2011 | 11:20 AM
do yourself a favor and upgrade the shocks and struts also
Old Feb 11, 2011 | 12:49 PM
I have already decided to replace the shocks & struts, but I'm reluctant to lower the car, because the roads here in northwestern PA are pretty bad & I'm not the type to sport a "too low for fat hoes" car. Is it possible to improve both the handling & ride quality without lowering the car?
Old Feb 11, 2011 | 01:03 PM
Yes, definitely. Just upgrading the shocks alone will be a big improvement. But given how high the Mustang sits already a small drop like with the Steeda Sport springs really won't make much of a difference in your streetability of the car. It will still have quite a bit of clearance and as long as you don't try to drive directly into potholes you should be A-OK!
Old Feb 11, 2011 | 01:33 PM
So if someone is planning to change out the springs, struts & shocks, is ordering the Brembo brake package still a good idea?
Old Feb 11, 2011 | 01:55 PM
If you still like the brakes and the wheels I'd definitely say so.
Old Feb 11, 2011 | 02:41 PM
thats the way I am going on my 06. The pro's I had on there were great for turning but hell as far as everyday ride went. To stiff and you feel every dip and bump. but that what they are for.
Old Feb 11, 2011 | 11:23 PM
mchief_k2's Avatar
Glenn I'm convinced that you've seen every post on this site....
Autotooner
Nov 24, 2017 12:42 PM
Fords4Ever
Oct 30, 2015 09:07 PM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
