Spark plugs
Old 1/11/12 | 06:32 AM
FordService's Avatar
Originally Posted by mach-1-morgan
I have a 2006 GT and have experienced the nightmare of breaking the plugs, while trying to extract them, at 40,000 miles. I'm now considering purchasing a 2013 and would like to know if Ford has resolved the spark plug issue?
These guys have some great info, mach-1-morgan. We did redesign the heads back in 07 and the issue was taken care of. You can PM me with your dealer’s name and order number when you place your 2013 order, so I can help you track it. Have a good one!
Deysha
Old 1/11/12 | 07:05 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Originally Posted by Pete07GT
Hit up TexasBoneKing, he works for Ford OEM and can give you a step in the right direction... If he isn't working on his Honda of course.
I have to get that thing running again! And I recommended running a high octane with a injector cleaner 1 week before you pull them out. Then before you do it run a seafoam treatment and drive about 10-15 miles for it to clear all out.
Then loosen the plugs a hair and let it sit all night with tranny fluid in the spark plug holes. Helps to loosen them up.
Old 1/11/12 | 11:20 AM
Here's the TSB. The procedure for the 4.6 is the same as the 5.4L.
https://themustangsource.com/attachm...sb08-01-09.pdf
Old 1/11/12 | 07:24 PM
2012 grabber blue gt's Avatar
Ok I do these things all day first think is to get either ford carb tune up or gm top engine cleaner basically the same stuff and a spray bottle of water slowly pour the carb tune up down the thottle body while lightly spraying water till they are both gone while the engine is running than take a 3/8 impact gun to the plugs verry lightly Use the gun they come out almost every time Prob like 9 out of 10 times if you brake one use the Lyle tool the OTC ford tool sucks
10/2/15 01:00 PM
9/23/15 03:21 PM
devildog1679
'10-14 Interior and Audio
9/14/15 02:17 PM
Quick Reply: Spark plugs
