Shifter question
Shifter question
I read how everyone complains about the 2-3 shifts on the stock shifter. My issue is the 1-2, especially when it's cold. It's very clunky and feels like its scraping something sometimes.
I have to catch myself and make sure I am pulling back precisely in a straight line. If I cheat even slightly to the left like towards my body during that 1-2 shift, I get that scraping feel.
Anyone else experience this?
Mine goes away after the car is driven for about 15 minutes. I suspect it's heavier duty gear oil in the track pack (don't quote me).
I double clutch it until the notchiness goes away.
You could also look into the MGW Race Spec shifter or the Blowfish Racing shifter bracket. These solutions correct the misalignment that can occur under heavy torque having a remotely mounted shifter.
Yeah, MGW works wonders on the driving experience. I still get a little bit of that on very cold days though. Now that it's warm here in NJ it's gone. What I really can't stand is that hill assist spring. That thing has to come out...
Or you can look at the Steeda Tri Ax!
http://www.steeda.com/index.php?subc...roducts.search
Best Regards,
TJ
Best Regards,
TJ
Deysha
I commented before about the MGW Race Spec Shifter, after some thought I guess I'd ask how long you plan on keeping your current car? If your going to keep you car for a number of years. Then spend the extra money and get the best shifter available, no other aftermarket shifter compares to MGW, go to there Wed Site and Watch the Videos. No other aftermarket shifter has the ability to adjust the horizontal shift gate. Go to a local {Car Show} Cruise In and ask until you find someone who has a MGW installed, ask them if you can sit in there car and shift it!! That will answer your question!
what about the original design MGW shifter? Does that solve a lot of the issue? I've seen a number of them used for sale. Not sure if I should get the old design and save a few hundred bucks, or shell out the dough for a new one.
That was also my dilemma. MGW is really expensive. I ended up grabbing a used 2 post Barton bracket from someone local to me and bought a new Barton shifter.
the two combined, never missed a shift nor have experienced lockout. It's a great setup and considering its A LOT less than MGW was a bonus.
There are many opinions about which Shifter is Best, many people have had good luck with other After Market Shifters other than MGW, The fact is they have been lucky, because there is no other After Market Shifter other than MGW that one can Adjust the Horizontal Gate, so the Shifter can be adjust Dead Nuts on, All Shifting problems go away if this Adjustment is made correctly! Yes, MGW is expensive, but you definitely get what you pay for!!!
