Satellite radio capable?
I have a 2012 base GT...window sticker says it is satellite radio capable. I used to have Sirius and since the car is capable and came with a free 6 month subscription, I figured I'd use it. I can't get the ESN to activate it because when I press the Sirius button it gives the message "No Sat Radio".
What am I doing wrong? It sounds like that message means the car is NOT satellite radio capable, but I have to assume that isn't the case. That would be pretty crappy to show a car is satellite radio capable when it's not. So I must be doing something wrong?
Satellite capable means one can be hooked up to the factory radio, the car doesn't come with it. And only premium cars come with the satellite radio with the 6 month subscription, your base car doesn't.
The dealer sells a kit that they can put in, usually runs about $500-$600.
Meh, they could claim an am/fm radio is satellite capable since you can buy a receiver and use the modulator to get the signal on the radio. Very disappointing.
Yeah, I understand that now, thanks. It's just kind of misleading in that it sounds like the system is ready to go but really all you have is a head unit that can control a sat radio receiver. That's all. I know now, but I definitely won't be giving Ford any more money for this "feature" to work.
I put a Sirius6 in my '08. The FM modulated type su#$s. The direct input through the Aux jack is the same as a factory install set up, IMHO.
The antenna is under the package tray. The mount is in the console into the Aux jack and power come from the jack in the console. You don't see it at all.
Get a decent remote if you do it this way. It's a pain to lift the armrest to change the channel.
9/16/15 06:44 PM
