Satellite radio capable?
Old Jan 28, 2012 | 03:11 PM
Overtorqued's Avatar
I have a 2012 base GT...window sticker says it is satellite radio capable. I used to have Sirius and since the car is capable and came with a free 6 month subscription, I figured I'd use it. I can't get the ESN to activate it because when I press the Sirius button it gives the message "No Sat Radio".
What am I doing wrong? It sounds like that message means the car is NOT satellite radio capable, but I have to assume that isn't the case. That would be pretty crappy to show a car is satellite radio capable when it's not. So I must be doing something wrong?
Old Jan 28, 2012 | 03:50 PM
Ltngdrvr's Avatar
Satellite capable means one can be hooked up to the factory radio, the car doesn't come with it. And only premium cars come with the satellite radio with the 6 month subscription, your base car doesn't.
The dealer sells a kit that they can put in, usually runs about $500-$600.
Old Jan 28, 2012 | 03:54 PM
AzPete's Avatar
No antenna on the trunk, no factory installed system....
Old Jan 28, 2012 | 04:07 PM
Meh, they could claim an am/fm radio is satellite capable since you can buy a receiver and use the modulator to get the signal on the radio. Very disappointing.
Old Jan 28, 2012 | 06:26 PM
LEwis26's Avatar
FM modulator and a direct hook up with control abilities are not the same thing.
Old Jan 28, 2012 | 07:37 PM
I realize that. And satellite radio capable is not the same thing as satellite radio direct control capable either.
Old Jan 28, 2012 | 08:10 PM
JimC's Avatar
legacy Tms Member
It is satellite radio capable - but it doesn't have the receiver is all. That just means that you can add the receiver (mounted in the trunk) and the radio will accept the signal and broadcast. But if you don't have the receiver the button for "AUX" or "SAT" has nothing with a signal.
Old Jan 28, 2012 | 08:47 PM
Ltngdrvr's Avatar
When you get the kit installed at the dealer the factory radio controls for the satellite radio will then work.
Old Jan 28, 2012 | 10:32 PM
Fat Boss's Avatar
Or get the iSimple kit and install it yourself for $200 plus shipping.
Old Jan 29, 2012 | 04:56 AM
Yeah, I understand that now, thanks. It's just kind of misleading in that it sounds like the system is ready to go but really all you have is a head unit that can control a sat radio receiver. That's all. I know now, but I definitely won't be giving Ford any more money for this "feature" to work.
Thanks, I'll look into that.
Old Jan 29, 2012 | 11:02 AM
825LTRGT's Avatar
I put a Sirius6 in my '08. The FM modulated type su#$s. The direct input through the Aux jack is the same as a factory install set up, IMHO.
The antenna is under the package tray. The mount is in the console into the Aux jack and power come from the jack in the console. You don't see it at all.
Get a decent remote if you do it this way. It's a pain to lift the armrest to change the channel.
Old Jan 29, 2012 | 05:32 PM
JimC's Avatar
legacy Tms Member
Every manufacturer, not just Ford, will list the radio as "satellite capable" -- because it is, you just have to buy something else to enable it.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
oneeyedgiant
Nov 16, 2015 12:23 PM
GLOCKer
Sep 28, 2015 05:20 PM
Sep 16, 2015 06:44 PM
