?s on future 5.0 modular engine
Old Jan 26, 2008 | 07:48 PM
mrk1984's Avatar
I know some of this stuff has been mentioned on other threads, but just want to get it all put together and get answers
First of all, is this in any way confirmed info or is it all speculation?
Is this based on current modular engine and if so, is displacement gained through larger bore (ala frpp mod boss 5.0) or a longer stroke (saleen h302)?
If it is large bore would it be made of iron, aluminum or something new?
People say it would be 4v, why, unless vvt is added to dohc it probalby isn't worth it ($$) to put 4v head manufaturing in the large scale if the engine won't be around for that long.( yes gt500 uses 4v but not the #s of trucks and mustangs 3v) So using the 3v with vvt should be just as good, right?
Finally, how much power could we expect from factory in either trim 4v or 3v?
>>>>long time reader(3+years) first time poster<<<<
Old Jan 26, 2008 | 08:06 PM
boduke0220's Avatar
idk but from the factory, IF thats a Gt model:expect somewhere from 325-350..n/a
Old Jan 27, 2008 | 01:29 PM
SuperSugeKnight's Avatar
There are 2 being tested right now. One based on the 5.4 (codename Coyote) and the other on a 4.6L (codename Bobcat). Sources say it will use a CGI block (Compressed Graphite Iron). It will have VCT, Direct Injection, and maybe cylinder deactivation. No clue as to DOHC or SOHC. Some sources say it will have a slightly smaller bore and slightly longer stroke when compared to Ford Racing's 5.0 Cammer race engine. Most of the info came from BlueII over at BON.
Old Jan 27, 2008 | 02:28 PM
Boomer's Avatar
Some miss info in here
Old Jan 27, 2008 | 07:40 PM
V10's Avatar
V10
I've heard that CGI is not quite the panacea many people think it is.
CGI weights almost as much as cast iron. If if the block is made thinner to save weight, NVH becomes a problem. Don't expect to see CGI anytime soon in passenger car engines, unless they'e Diesels.
Old Jan 27, 2008 | 08:01 PM
Boomer's Avatar
I'd guess AL over CGI
Old Jan 28, 2008 | 12:21 AM
bob's Avatar
bob
Hard to get a bigger bore with the AL block, the new Boss Mod block might be pretty close to the next 5.0 Mod motor ( 3.70 x 3.55 ), Could also go 3.65 x 3.65 or 3.60 x 3.75 or there abouts, although 3.70 x 3.55 would do wonders for breathing on the mod motor, IIRC on a 4v engine going to a 3.70 bore gets a 20-30 cfm increase in airflow compared to the 3.55 bore. I imagine a 3v head would do about the same.
It would be real nice if they could get an as-cast port to flow about the same as the FRPP ported heads and combine it with the 3.70" bore, that'd be in the neighborhood of a 50-60 cfm increase in cylinderhead flow over the current 3v head on the 3.55 bore with no real increase in port volume.
Old Jan 28, 2008 | 05:57 PM
V10's Avatar
V10
My understanding is the larger bore mod motor will come from the use of siamesed bores.
Of course Ford has been looking at ways to increase the mod motor bore for 10 years, none of which have made it to real production (Cammer not counted as it's a limited warranty aftermarket crate motor).
Old Jan 28, 2008 | 08:06 PM
bob's Avatar
bob
Isn't the 3v AL block siamesed bore now? I thought the cast iron blocks were siamesed bore, but I see they aren't. Then again I like an idea you had awhile ago V10, put the Mod motor on FE bore centers, might make it a bit longer, but you could drop the deck by a good amount to help offset any gain in weight
Old Jan 29, 2008 | 06:44 PM
V10's Avatar
V10
I thought it was too, but the last time we had this discussion on another thread I think the conclusion was the AL block is not.
It wasn't my idea about the FE bore spacing. Ford has already done this withi the new boss motor. It has 4.54" bore spacing (.090 less than a FE) and the FE / mod type deep skirt block.
Old Jan 30, 2008 | 01:19 AM
Black331's Avatar
Slightly more bore and stroke..
Old Jan 30, 2008 | 11:50 AM
jsaylor's Avatar
Not long ago it took me a while to find a definative answer on this myself. Aluminum Mod motor blocks are indeed siamese bore, or at least they were back when DOHC heads were still getting dropped onto them. Since the new 4.6L and 5.4L 3v motors used a slightly revised engine block this could have changed, but I would be surprised if this is the case since there is little reason to do so.
And for all the talk about cylinder wall thickness issues it appears that the biggest obstacle to a production 'big bore' Mod motor may be the obvious problems with head gasket strength and durability given the small amount of area available between cylinders..
Old Feb 9, 2008 | 05:47 AM
3Mach1's Avatar
Here is an update from fourcam.
Major turmoil over at the Ford camp is causing major changes as I'm sure you can imagine.
As of now the 5.0L/4V revised Modular based engines used in the '11 Mustang GT will have direct injection, VVT, revised aluminum blocks with longer sleeves to accomodate the longer stroke, a and 3.6X" bore. Weight reduction is also part of the new Stangs future. Ford is also testing a twin turbo version of the 5.0/4V motor though production is doubtful.
6.2s Boss V8s are now relegated to truck only duty. As for the Boss line of engines, they are 2V/OHC iron block, with plans for an Al version, displacements ranging from 5.8-7.0L, possibly 4V heads, and twin turbo versions are being tested. The Fe block weighs 211 pounds and will definitely be used in the F series. It has 102 mm (4.015") bores on 115 mm spacing. It does NOT have siamese cylinders. It DOES have under piston oil squirters. The main journals are ~ 75 mm diameter and the bulkheads are pretty thick. As for bore/sroke that's approx. 4.015"x3.73" for the 6.2.
Old Feb 9, 2008 | 08:47 AM
Boomer's Avatar
The turmoil part was part of the original post...
The 5.0 stuff was added
Sounds like the stang is going on a BIT of a diet
Old Feb 9, 2008 | 09:35 AM
mrk1984's Avatar
Longer sleeves, does that mean it will have a larger deck hieght compared to the 4.6?
Old Feb 9, 2008 | 06:04 PM
V10's Avatar
V10
From the way 4cam wrote his post the answer sounds like it does not have a taller deck height. If the bore is 3.60" (91.44mm) it would require a 3.74" (95mm) stroke to get 5.0L (305 CID). Of course Ford could call 301.6 CID a 5.0 like they did with the old 5.0 engine. That would be a 3.70" (94mm) stroke.
Keeping the same deck height reduces manufacturing & tooling costs, but the longer stroke means higher cylinder sidewall loading which increases friction losses and cylinder wall + ring wear.
I've wondered for a long time why Ford didn't make a 5.0L mid deck in between the 4.6 & 5.4.
Whatever Ford does, I just wish they would get of the pot and make a decision. Chrysler designed the new Hemi and put it into production in less time than it takes Ford to make a simple engineering or marketing decision.
Old Feb 9, 2008 | 07:00 PM
MustangFanatic's Avatar
I too would like to see Ford offer a mid-height block between the 4.6L and 5.4L and at least get us to a 3.65 x 3.65 architecture. V10, I'm with you - Ford just needs to select a strategy and just move forward, we are all tired of waiting.
Old Feb 9, 2008 | 09:30 PM
So the 5.0 will be in the 2011 and not the 2010?
Old Feb 10, 2008 | 06:13 PM
V10's Avatar
V10
3.65 x 3.65 would make a nice 5.0 engine. With that stroke the deck high could stay the same.
Old Feb 10, 2008 | 06:37 PM
Very true, wouldn't have to increase the deck height for that bore - I was mixing two thoughts in one sentence - must be the cold meds
