Rust bubbles found! 2013 Mustang.
#61
Moderator
What year is your car ??? If you still have your factory 3 year/36k bumper to bumper warranty.. Ford cannot deny your claim and if your dealer does deny it, then fight it.. I would also contact Deysha, as she's our Ford customer service representative on this website and she will handle and investigate your claim on your behalf by providing her with your info regarding your status..
#62
Moderator
Before you look into replacing your hood.. Read my response to your first post ! Otherwise American Muscle has fiberglass hoods to select from that are reputable and competitively priced..
http://www.americanmuscle.com/2010-mustang-hoods.html
#63
#64
Kind of off topic, but does anyone make a STOCK GT fiberglass hood with the vents and everything for a 13-14? Just wondering, in case if I have this problem down the road. I haven't been able to find one
#65
#66
I'm assuming that if 2014's still have the issue, that the manufacturing process has not been corrected and existing stock of parts will suffer the same fate...maybe years down the road, but the same fate nonetheless.
#68
I think there are plenty of good hoods out there, so if it happens to me, I'd think any used one (by that time) should be safe.
Is there a way to tell the likelihood of future problems on a new unpainted hood?
My hood was repainted a year and a half ago with no signs of reoccurrence. They did a great job. Fingers crossed.
#69
I actually stand corrected as of like an hour ago. There's 2-3 air pockets forming on the right hand ridge of the inner hood. Nothing too alarming especially since it's not close to the front. Still, not surprising.
#70
Moderator
And FYI.. I'm also not very fond of fake scoops either, however I would think the hood manufacturers listed on AM's website should have several different styles of fiberglass hoods to select from other than those with scoops on them..
If on the other hand they don't ? Then the best advice I can provide, is do a google search !
#71
Not all fiberglass hoods have fake scoops. Some of them have ridiculous cowl heights instead.
Seriously, searching everywhere I could, I only found really aggressive designs. A fiberglass version of the stock hood would be a welcome alternative.
#73
Ford is still making older model car parts 2013/2014. I got my hood last week from Ford Factory. They don't just make one part one day, they tally it up and make a bunch in that day, hence the me waiting 5 months for parts.
Well, I bought one of the last 2014s (my blend date was May 13, 2014), so if I get the issue it probably was never corrected. And I assume that they are no longer produced once the production line moves over to the new model.
The body shop I spoke to about this seems to think the problem can be permanently solved by stripping, redoing the seam seal, and repainting. If I were to get the problem, I might consider going this route instead, especially if done under warranty or partially covered by Ford and assuming they won't pay for a new hood.
#74
My thoughts exactly. Everything fiberglass looks ridiculous. The only one I can tolerate is the Stalker 2 from Cervinis and I am not too keen on the open hole where the scoop is. They also weigh about double what the aluminium one weighs.
#75
Moderator
However despite my best efforts in addressing both your questions and concerns.. The bottom line is this, you didn't make any effort towards submitting a response whatsoever.. End of story !
#76
My apologies, the three year warranty is over. I PMed Deysha, no response yet.it is a 2011 not a 2014, typo. I saw the links and have been researching hoods like crazy. I like the Cervini hood, specifically the Stalker II for this car. So I hope this answers all your questions. Thanks for the input so far
#77
Moderator
So in the end, your only other options I can think of is (A) Purchase a replacement hood from Ford (B) Have your factory hood repaired and hope it fixes the corrosion seam issues from coming back and (C) Look into the Cervini "Stalker II" hood and others in which you happen to like..
At any rate, keep us posted and let us know how everything turns out with Deysha as we all hope that a solution will somehow be found..
BavarianStang
9/5/15 05:55 AM
