Rust bubbles found! 2013 Mustang.
But they have approved replacing it? Was this a decision by Ford Canada warranty?
I've had this problem twice within a year and both times they only fixed it, even after contacting customer support.
Glad you got your's replaced.
Yep! Dealership got it approved by Ford Canada. Just waiting for the hood supply in Michigan.
I just found 4 spots of rust under the paint on my 13 Mustang. It's 6 months out of the manufacturers warranty. I bought extended but they refuse to cover it under that. Now they want pictures but since they won't cover it I don't know why. Very disappointed in Ford. I baby my car and had planned to keep it forever.
Rust under the hood? Usually Ford will cover the replacement or fix it if its under the 3 year warranty period.
I've heard that fixing it doesn't work, rust will still occur (scroll up). Replacing the hood usually fixes the issue as they use different material making the hood.
I had the corrosion on the bottom side of my hood. The dealership repaired it and so far it has not returned. If it does I'll trade the car for a used truck and not think twice about it. So tired of car manufacturers that charge this kind of money and cut corners all over the place.
Nah, mechanically the car has been flawless. The Pirelli tires were crap so I had to ditch them and you would think for 28 grand I could get Ford to paint a doggon rear axle instead of just leaving it bare metal so it develops a coat of rust in short order.
Get a can of Rust Cure spray and spray the hell out of it underneath.
I bought some navy jelly. When it warms up I'll get up under the car and remove the rust and spray it down with some rustoleum high temp paint. The point being, I shouldn't have to do that for a car that cost me 28 grand.
#40
Hood replaced today under warranty after waiting 5months, paint matches 100% (done locally).
Before:You can see the seals were not sealed all around by Ford.
AFTER: Body shop sealed all around. Paint matches 100%.
