Remove cats for track - couple questions
Old Apr 27, 2013 | 09:01 AM
dmichaels's Avatar
I'm looking at swapping out the cats for track events when I get the new Mustang, curious if anyone else has done this? Should be a fairly easy part to swap out, anyone ever dyno with/without cats?
I know the CEL will go on, not too concerned as I would only use this for track days. I had a cat-less setup on my old car for the track and it really opened up the top end.
I like a more free flowing exhaust setup for track days (and by track I mean road courses, not the drags), wondering if anyone else has experimented and found it worthwhile to do this!
Old Apr 27, 2013 | 11:13 AM
kylerohde's Avatar
Seems like a lot of work for a few horsepower. Why not get a higher flow full cat-back exhaust if you're that concerned about the peak hp?
Old Apr 27, 2013 | 03:43 PM
dmichaels's Avatar
I will likely eventually go full cat-back, but the main restriction in the exhaust is the cats... for $100 or so it's cheap and (I assume) quick to swap out for a couple day event.
And I'd rather spend the $500+ on track time than on a cat-back system when GT500 axle-back mufflers get me the sound I want. There are noise limitations at my local track, so near stock dB is what I try to go for...
Old Apr 27, 2013 | 09:15 PM
jaywoo's Avatar
With that check engine light the PCM will also think the cats are failing and start dumping extra fuel to compensate. You will lose power with that. You need a tune to adjust for that.
Not to mention that the cats aren't all that easy to remove. The bolts are kindof a pain in the butt to get to.
Earlsays
Aug 5, 2015 07:10 AM
junkman9096
Aug 3, 2015 10:58 AM
Bert
Jul 25, 2015 02:13 PM
