Rear end (possibly rear sway bar?) squeak?
try this: loosen the lateral stiffener bar, loosen the pan hard bar, while the suspension is loaded. re-lube the phb, and torque to spec.
for me that was the final resolution to the squeak. I had tightened the lateral stiffener bar too far!
The purpose of a sway bar is:
- to reduce body lean
- dial in/out, over or under steer.
as long as you don't drive like you want to win the indy 500, you should be fine. Just find some speed bumps and drive over them. You will know if the squeak is coming from the sway bar, or from something else.
(he changed his shocks, so something else might have changed in the setup).
Maximum Motorsports actually recommends you to remove your rear sway bar if you lower your S197 and don't upgrade the front bar, if you're running a square tire setup. The Boss 302S racecars run no sway bar also.
OP, you might want to also check the panhard bar for squeaks as well. So, taking a drive without the sway is a good idea.
Btw, if I get my coilovers, and this squeak is still there, I'm getting rid of that sway bar if that's the case. Going with competition spring coilovers from steeda probably. 200lbin rear and 225lbin front I think...
Very interesting!! I did lower my mustang 1.1in in the front and 1.7in in the rear.. used Eibach Sportline springs, which seem pretty stiff. I also upgraded almost everything, so hat would include the front and rear sway bar, now eibach. but only the front one is adjustable. I do have a squre set up. so if I wanted to, I could run with no rear sway bar?
or is that mainly for track use?
Very interesting!! I did lower my mustang 1.1in in the front and 1.7in in the rear.. used Eibach Sportline springs, which seem pretty stiff. I also upgraded almost everything, so hat would include the front and rear sway bar, now eibach. but only the front one is adjustable. I do have a squre set up. so if I wanted to, I could run with no rear sway bar? or is that mainly for track use?
Ok update....
as you know last night, I removed the entire sway bar and cleaned it and regreased every bushing. Then this morning, I got a grease gun and Mobil 1 synthetic grease, and had my buddy at the shop grease the BMR panhard bar bushings. I drove it around for a little bit this pm, and so far, no squeaks.
I'm not going to get too excited on this, as I know there is a possibility of it coming back. From what I understand, the STIFFER you make the car, the more squeaks will come with it. Part of having a good handling car. Ok, I can live with that then. I am planning on getting Steeda coilovers soon, so it will get even stiffer. Bring it on.
besides, it's still stock since I sold you the AirRaid, right? see? I have the stock airbox
![Firedevil](https://themustangsource.com/forums/images/smilies/firedevil.gif)
#40
