Random "tick" while driving (may or may not be "ignitor tick") anyone else have this?
Old Jun 12, 2013 | 06:47 AM
MRGTX's Avatar
My 2011 now has 16,xxx miles on it... it has been hilariously fun and fantastic all around but I'm starting to notice a few noises that I want to figure out before the warranty is up in August!
So I'm familiar with the famous "ignitor tick" and my car definitely has this. When the motor is fully warmed up, you can hear a random/semi frequent "clack", much more apparent with the hood open. I understand that this is likely related to a tensioner on the AC belt... or something like that...but it's common and I'm not too worried about it.
The one that's really annoying me is a sound that's similar but seems that it must be louder (and therefor from a different origin???) because I hear it while driving. It's also a "tick" sound, usually happens when I'm getting rolling from a stop or accelerating after downshifting to 2nd...but it's not something I can cause to happen at will.
It's also possible that I only notice it at slower speeds because there is less wind/road noise.
Any ideas? Anyone else have this?
Thanks for any input or suggestions!!!
-Mike
Old Jun 12, 2013 | 07:51 AM
Brandon302's Avatar
Take it in for service...the tick you're referring to with the tensioner is not entirely benign.
Old Jun 12, 2013 | 08:12 AM
MRGTX's Avatar
Thanks, Brandon302!
So I should be worried about this? Hmm... I'll make an appointment today.
Old Jun 12, 2013 | 09:07 AM
Brandon302's Avatar
I wouldn't say worried, however if it doesn't seem right I would suggest going to the dealer to have them inspect it instead of trying to diagnose it online. And on a side note, I think the tick you are referring to in the title is the injectors.
Old Jun 12, 2013 | 10:12 AM
kylerohde's Avatar
I had a tick and it ended up being the water pump - covered under warranty thankfully. Take it in!
Old Jun 12, 2013 | 01:08 PM
MRGTX's Avatar
Thanks, guys. Will do..and I'll share the results.
Old Jun 13, 2013 | 08:01 AM
FordService's Avatar
-Mike
Hi MRGTX,
I recommend you bring it in to your Ford dealer as soon as possible and have it looked at. Your Service Manager is in the best position to look into this for you. He can check into any warranty, Recalls, or Customer Satisfaction Programs that may apply to your vehicle. Let me know the outcome.
Deysha
Old Jun 27, 2013 | 09:26 AM
MRGTX's Avatar
Originally Posted by FordCustomerService
Hi MRGTX,
Deysha
Thanks.
The service department at Sarat Ford in Agawam, MA is always great...I made an appointment, brought it in and my Mustang promptly stopped making the noise!
Typical, right?
They took the car for a ride (yeah, I trust them) and heard nothing...but at least it's on record, right?
Driving the car later in the evening, the clacking was back to full volume (of course) and I suspect the car was just not hot enough when I brought it to the dealership.
So no answers at this time. I was reminded that my powertrain warranty is 5/60,000....but this doesn't help if it's related to the AC compressor/tensioner or some other non drivetrain component, right?
Old Jun 27, 2013 | 10:05 AM
Brandon302's Avatar
How would your warranty not help, the water pump issue should be covered. There must be a way to have them check to see if the TSB needs to be applied with the noise, must be other symptoms.
Old Jun 27, 2013 | 10:47 AM
MRGTX's Avatar
The warranty might not help if it's related to the AC system since that's covered under the bumper to bumper warranty which is 3/36,000. Several forum members with 2011/12 cars have already had to pay for $2000 AC compressors that failed shortly after 36,000 miles. But yes, I assume that a water pump would be covered under the powertrain warranty.
Good point about the TSBs. I mentioned the TBSs and the tech looked them up... found two that might be relevant but said that they needed to hear the noise first hand before following up on them... which is reasonable, of course.
To my dealership's credit, at no point did they imply that I might be a hypochondriac about these noises.
Old Jun 27, 2013 | 10:51 AM
Brandon302's Avatar
That is always good, seems a little silly though that they wouldn't just check since it would proactively stop damage to the motor.
Old Jun 27, 2013 | 11:09 AM
14Glassback's Avatar
I am sure this has been covered before on other threads... But does anyone know the cause of the loud Clack noise present when letting the clutch out?... I know it is a normal noise with the vehicle. Just curious what it is?
Old Jun 27, 2013 | 11:14 AM
MRGTX's Avatar
Have you driven other Mustangs and heard this? I'm not sure that's normal. Mine sure doesn't make any noticable noises related to the clutch actuation.
Old Jun 27, 2013 | 11:21 AM
Brandon302's Avatar
You mean there is a clack when letting it out/depressing the pedal, not constant though right. If so I would say that is probably normal pressure plate or throwout bearing noise.
Old Jun 27, 2013 | 12:14 PM
Yes... Really loud sometimes when pulling into the garage! Sounds like the 5.0 wants to jump out of there! I suspected it might be oscillations of the springs in the pressure plate. Just loud... Thanks!
Old Jun 27, 2013 | 12:41 PM
Brandon302's Avatar
I would get that checked out, I can hear the engagement/disengagement but nothing super loud.
Old Jun 27, 2013 | 08:07 PM
I totally did not mean to Hi Jack this thread... Sorry to MRGTX!... I think my noise is normal... However this weekend I will try to take a video and have you guys take a listen... Starting my own thread of course!... Sorry again MRGTX!
Old Jul 5, 2013 | 01:57 PM
wanted33's Avatar
[QUOTE=MRGTX;6647571]Thanks.
Typical, right?
And I thought I was the only one this kinda crap happened too. Good luck, hope they find what is causing the problem soon.
Old Jul 8, 2013 | 08:28 AM
Thanks.
Typical, right?
Let me get it escalated for you, MRGTX. PM me with your dealer, VIN, mileage, full name, and best daytime number.
You should get it checked out by your dealer, 14Glassback. Then PM me with the info I requested above.
Deysha
FromZto5
75
Oct 5, 2015 02:27 PM
Evil_Capri
Sep 11, 2015 08:39 AM
oldnjguy
Sep 10, 2015 02:39 PM
Road_Runner
Sep 10, 2015 01:14 PM
Road_Runner
Sep 10, 2015 11:28 AM
