Radio screen will not turn on - 2010 GT
Old Jul 24, 2019 | 05:28 AM
Mgalli's Avatar
The radio works, just the display won't turn on. When I turn on the headlights, the climate control and radio buttons all light up, still not the radio screen. All interior lights work.
Things I've tried without success:
* Pulled and replaced fuses 39, 29 and 3.
* Started car without a Bluetooth connection.
* disconnected battery for 8 hours.
I'm at a loss guys. I'd really appreciate some help. Thanks in advance.
Old Jul 26, 2019 | 07:43 AM
Bert's Avatar
Hi, I think I replied to your post on the other forum, but wanted to give you a reply here also: it sounds like the problem is internal to the radio (burnt out light bulb?) or perhaps there is a fuse in the wiring behind the radio; unfortunately no easy fix that I know of.
Old Jul 26, 2019 | 07:51 AM
Mgalli's Avatar
Thanks for the response! I'm trying to figure out the location of the fuse behind the radio console before I start taking things apart. Any idea where that might be?
Old Jul 26, 2019 | 01:29 PM
Bert's Avatar
I am not sure if there is one . . . best bet would be to find a wiring diagram but I'm not sure where to find one . . . Cruchfield has good installation instructions that might show it
Old Jul 28, 2019 | 01:17 PM
VIP1's Avatar
That display doesn't use a bulb or led. It is a VFD like on a VCR/DVD/Blu-ray player or single-din aftermarket radios.
First confirm it is getting power. If so, then possibly the display driver failed or a solder joint(s) on the display went bad. Solder joints can be re-flowed it that's the problem. However, replacements displays are $40 - $90 on ebay.
There should be a pinout around where you can see which pins on the harness are power and ground to confirm whether or not it is getting power.
VFD = Vacuum Fluorescent Display
https://en.wikipedia.org/wiki/Vacuum...escent_display
Ronnn
'10-14 Interior and Audio
Oct 30, 2018 06:35 AM
DAN4D
May 4, 2011 05:25 PM
06GT&06MCS
05-09 Interior and Audio Mods
13
Dec 26, 2005 10:01 PM
70mach1yellow
Oct 13, 2004 04:18 PM
