Race Ramps!
Old Mar 13, 2013 | 09:50 AM
fdesalvo's Avatar
Race Ramps!
I just picked up a pair and will be using these this weekend for an AB install. These are very light in weight while being obscenely strong. Here are the specs:
· Ideal for low ground clearance vehicles with tires up to 12" wide.
· Incline of only 10.75 degrees,
· 8" lift
· 3,000 pounds capacity per set while weighing only 10 pounds per ramp.
· Will not slide across a garage floor, dig into an asphalt driveway, or scratch or otherwise damage a cement or painted floor. They can be used on grass, dirt, or almost any other flat surface, and they will never rust.
· Race Ramps car ramps come complete with straps for easy carrying and storage.
Old Mar 13, 2013 | 10:36 AM
Nocturnal'14's Avatar
I was looking into getting these....but thought about the 62" ones that have a 10" lift to them.
Old Mar 13, 2013 | 10:52 AM
fdesalvo's Avatar
Yeah, brother - those are really nice, too.
Old Mar 13, 2013 | 10:54 AM
Rando's Avatar
10" would be ideal. Mine only go to 6" and it's **** near useless if you want to access the middle of the car.
Old Mar 13, 2013 | 11:31 AM
Mikey's Avatar
· 8" lift
I have these same ones, I like them a lot
Old Mar 13, 2013 | 11:33 AM
fdesalvo's Avatar
Sweet! Have you found that you can do most of your maintenance and mods with these? Anything you can't do aside from dropping a motor/tranny?
Old Mar 14, 2013 | 09:57 AM
kylerohde's Avatar
I've got an all-metal similar set from Griot's Garage that I use, but when I have to do bigger stuff, I go here: http://www.diyautorepairkc.com/. I hope more of these types of places pop up all over the country because working on a car that's on a lift is sooooooo nice.
Old Mar 14, 2013 | 10:00 AM
fdesalvo's Avatar
Old Mar 14, 2013 | 10:13 AM
TheReaper's Avatar
How fast do you hit them to get 6 feet of air.
AdPock
Oct 16, 2015 02:58 PM
Sep 30, 2015 07:02 PM
RoushRS3
Sep 29, 2015 08:03 PM
southern stang
Sep 26, 2015 04:19 PM
