question about lowering springs
Old May 17, 2014 | 07:14 PM
texasgtguy's Avatar
Can someone kinda give me the run down on what these do for your car? Is it all about looks or does it really improve handling\responsivness as well?
Old May 17, 2014 | 07:17 PM
Ltngdrvr's Avatar
Lowering the car lowers its center of gravity, the car doesn't roll in the turns as much.
Old May 17, 2014 | 08:05 PM
bob's Avatar
bob
Unfortunately lowering a Mustang (or any vehicle) alters the suspension geometry and all things being equal (if spring rate isn't changed) will increase body roll. While never billed as such its part of the reason for increased spring rate and higher rate sway bars as well.
The primary benefit other than appearance is a lower center of gravity though.
Old May 19, 2014 | 01:23 PM
bjbsav's Avatar
On that same topic has anyone had a shop do it? How much should I expect?
Old May 19, 2014 | 01:53 PM
texasgtguy's Avatar
cant tell ya right now, but as soon as i get mine in, im going to have them installed and an alignment.. ill let you know once i get it done though.
Old May 19, 2014 | 01:56 PM
bjbsav's Avatar
Thanks, I know the shop near me charges $69 an hour. I had them install my axle backs last week.
Old May 19, 2014 | 05:25 PM
dmichaels's Avatar
Handling is significantly improved with stiffer springs and shock/strut upgrade. With stiffer lowering springs (nearly all are stiffer than OEM), roll is reduced.
I wrote up a review of my shocks/struts/springs/mounts over in the "suspension" forum if you want some more detailed thoughts
Old May 19, 2014 | 06:41 PM
texasgtguy's Avatar
hey thanks buddy!
Old May 20, 2014 | 06:16 AM
bob's Avatar
bob
That's why I said all things being equal, if spring and roll bar rates aren't changed compared to the original rates the vehicle will experience increased roll. IIRC this is due to the way leverage is applied by the suspension on the springs. As the vehicle is dropped the geometry is altered increasing the leverage and requiring increased rate to compensate.
If say Ford had designed the ride height of the car to be adjustable without altering geometry then not as much rate would be required for increased performance.
Old May 20, 2014 | 08:14 AM
dmichaels's Avatar
Yep, I don't disagree at all, was just pointing out that you really can't find lowering springs that are not stiffer, so while I agree with your statement, it is typically not something anyone worries about (increased roll, etc) when lowering purely because of the available components.
Old May 20, 2014 | 09:24 AM
Primarily looks, with improved handling and ride quality (subjective - depends if you think firmer is "better"...I do)
As for the installation, with my latest round of updates, I will never pay a shop to install springs ever again. We did the whole thing in my garage (front and rear) in under 2 hours with the ride tools. It was so easy, it was embarrassing. I used to pay a shop 400 bucks or more for the installation, not including alignment. It was crazy.
Old May 20, 2014 | 12:24 PM
puma1552's Avatar
I must lower mine sooner than later...saw an OEM fresh (the way I like it) DIB Brembo car this morning on the freeway lowered just right and it looked so ungodly much better than mine...
Old May 20, 2014 | 02:17 PM
Horspla's Avatar
Yup. You wouldn't think in an inch or so would make that much difference, huh? After I put the 20's on mine it looked so silly I almost left it in the garage until I lowered it Monster mudder before, sports car after, just that simple!
John
Old May 20, 2014 | 02:18 PM
Bocefus's Avatar
Agree with an earlier post. I used to pay for it on other cars. Never again. Not paying someone $500 to install springs struts etc. join a local mustang club. I am sure there would be guys in the club that have the tools and can show u how to do it. Don't waste your money. Do it yourself, the satisfaction is worth the sweat.
Old May 20, 2014 | 02:50 PM
tj@steeda's Avatar
Here is a video that will give you a little more insight:
They are currently 20% off ... good time to order & take advantage of the sale!
Best Regards,
TJ
dbent15
Sep 5, 2015 12:15 PM
Sep 2, 2015 07:33 PM
