Power or suspension first
You can take your Mustang to this level ... will be a nigh and day difference!
http://www.youtube.com/watch?feature...&v=a_snajrgC0g
Let me know if I can help assist with anything moving further? You can reach me at tim@steeda.com.
Best Regards,
TJ
Best Regards,
TJ
Video Link: http://www.youtube.com/watch?feature=player_embedded&v=a_snajrgC0g
Best Regards,
TJ
Best Regards,
TJ
I agree with everyone else that likely your best upgrades are going to be suspension and tire related. Help get more of the horses to the ground. Having said that I read many threads about upgrades on the forum I do not understand. People take a Brembo car that they have already paid additional for with upgraded wheels, tires and suspension... Then they swap out wheels, tires and suspension. I understand that there are better parts out there... But do not understand why starting with a Base GT to add these upgrades to is not financially smarter? Am I missing something?
But yes, have known of quite a few people who specifically order certain packages on their car and then proceed to later replace almost all the components that make up that package, sort of silly...
This is a rather muddy subject since Ford never really clearly states what is different on a Brembo car. However every legitimate source I have found says wheels, tires, shocks and sway bars are upgraded. Best source I found for info was Brembo50.com
That is fuzzy math ...
Yes, but we just supplied the parts for the video and the magazine did the write up. I am surprised after showing that video many times ... you were the first to notice. My hat goes off to you for your attention to detail.
Best Regards,
TJ
I know I am always picking on you guys, but on a serious non-biased note, the video states .98g's prior and 1.07 after which is a ".9" increase. Shouldn't that be a .09g increase?
Best Regards,
TJ
Thanks for the info. I looked at the Brembo5.0 website and was surprised at the differences between the Brembo package and a standard GT. I thought it was just the front brakes, wheels, tires and some programming changes in the traction control. I had no idea that it also included different springs, shocks and control arms. This gives me more to think about before purchasing suspension components.
Yes you do have amazing roads - my parents live in Vonore, about 15 mins from the start of the Dragon, Cherolah Skyway, etc. Amazing part of the country!
Have you ever considered simply painting the rear calipers the same red as the front? It would give you the appearance of having the same calipers front and rear, and would only cost a few bucks.
Brembo suspension is great IMO, except for the control arms and panhard, which is all I'm replacing.
I did that... But it makes it so much pop out making it more relevant of it being smaller.
The front and rear calipers were painted the same color from the factory, which on my car was a flat black. The front have red BREMBO lettering. The rear rotors just look too small for the 19 inch wheels. It is strictly a cosmetic thing as the car stops amazingly well in stock form.
Agreed, I see many Boss owners upgrading their cars also.
My previous car was an F-body with an autocross suspension. I'm beyond the point where I need a teeth rattling stiff suspension so when I drove my Brembo GT for the first time I was pleasantly surprised how well it handled. That being said I do feel that there are a couple areas that could use some improvement. Number one is quality Dampers, "never underestimate what a set of quality performance shocks/struts can do for any car". After that a Watt's link and upper and lower control arms will keep the car composed and controlled for handling and trips to the drags.
I was looking at upgrading the shocks/struts first, but not sure if I should go ahead and upgrade the springs as well, since I will already have the fronts out of the car. I would like to go to an adjustable shock/strut set up to let me tailor the ride depending on the particular day. What dampers did you put on your car?
If your set on doing springs then do shocks springs together since it all has to come apart to do (front) springs.
The Mustang is still on factory shocks/struts but when I do upgrade I am going Koni sports (yellows). I had these on the F-body and they really make a difference in all situations.
#40
I am not set on springs yet, I just don't want to do the shocks and then tear the car apart again if I decide I need the springs. I would like to minimize the nose dive on hard breaking and reduce the body roll a little more. I drive the car most of the time and do not want the car too stiff to where it is uncomfortable.
