Piston Oil Squirters vs conventional means....
Old May 2, 2010 | 03:31 PM
The_F5_Assassin's Avatar
discuss the differences.....
Old May 2, 2010 | 03:37 PM
YardSpecial's Avatar
oil cools the bottom of the pistons, less chance of detnation..........
Very common in high end cars.
good read:
http://www.importsuci.org/tech/pistonoilsquirters.html
Old May 2, 2010 | 03:59 PM
YSUsteven's Avatar
Heat is bad. Oil squirters help cooling = good. nuff said.
Old May 2, 2010 | 04:08 PM
Ltngdrvr's Avatar
Why?
You have no choice so why discuss it?
And what about piston pin / cylinder wall oiling vs conventional setups?
Old May 2, 2010 | 11:21 PM
Gene K's Avatar
Might as well discuss splash oiling vs pressurized oiling. The Chevy Stovebolt 6 was the last splash oiled engine I can think of. You can get by with splash in some locations but dedicated delivery is almost always better.
Old May 3, 2010 | 01:34 AM
Fazm's Avatar
not almost always
Old May 3, 2010 | 04:58 AM
fdjizm's Avatar
Yea always.
Overboost's Avatar
Sounds like the OP needs to stop posting new threads here and using a little website called Google.
Old May 3, 2010 | 09:48 AM
What are you kidding? TMS is the google of Mustangs!
(Although our search function could be lots better.)
Old May 3, 2010 | 10:52 AM
krnpimpsta's Avatar
Here is how to use the search function on TMS:
Click on "New Topic" or "Reply" and enter your search question in the "Message" box.
Then wait 12-24 hours and your search results will come in, on that thread, by means of magic.
We are still working out the bug where half of your results will come up with things like "USE THE SEARCH FUNCTION NOOB!!!" and etc., but just ignore those, you'll find your answer somewhere in there.
Old May 3, 2010 | 10:56 AM
06GT's Avatar
Oil squirters are not radical or new components.
Old May 3, 2010 | 11:27 AM
Talking
For a Ford it is.............
Most Ford owner don't chnge their oil, so these will plug up real fast !
Old May 3, 2010 | 02:19 PM
hawkeye18's Avatar
I question the logic used to arrive at the conclusion that Ford owners are any less diligent about oil change intervals than any other brand's driver is.
Old May 3, 2010 | 02:26 PM
I'm guessing his green smiley meant it was TIC.
My 83 F150 4X has 254k and still pullin' stumps & skiddin' logs here at the ranch.
And I've never changed the oil...
Course that 300" I-6 doesn't have oil squirters either.
Old May 3, 2010 | 02:40 PM
hawkeye18's Avatar
Dammit, I didn't see it! You gotta stop hiding it up there! lol
Old May 3, 2010 | 03:15 PM
ManEHawke's Avatar
Powerstroke Diesels use oil cooling jets under the pistons. I have yet to see that system ever go bad.
Old May 4, 2010 | 03:21 AM
Slims00ls1z28's Avatar
Lol I actually know one that went close to 60k (being real conservative here I think it was closer to 80k) in a 99 F150 before the oil pump clogged up and started tapping before getting a real oil change. Still went 250K pulling many a vehicle. I was and am duly impressed. But he owns one of each of the big 3 so it's not a hit to a "Ford" owner.
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
OneCoolGT
Off-Topic Chatter
Sep 3, 2015 07:50 AM
