Oil Separator update
Old May 8, 2012 | 01:59 AM
BOSS302R's Avatar
2013 5.0 , was installed at 20 miles, now have 800 miles.
Driver side had maybe 1 drop of oil in it. passenger side had about 1/8 of the can was full. intake and throttle body was clean of oil .
im glad i installed these.
Old May 8, 2012 | 07:56 AM
steve03gt's Avatar
My Passenger side one has lots! Never bothered with the Driver
Old May 8, 2012 | 09:37 AM
MyStang2010GB's Avatar
I was told this is an issue until the rings are seated. Is this true or is this just the nature of this beast??
Old May 8, 2012 | 10:11 AM
steve03gt's Avatar
It will slow down, never stop.
Old May 8, 2012 | 10:19 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
This part doesn't have to much to do with the rings. More to do with the pcv valve letting oil by
Old May 8, 2012 | 10:27 AM
Plus its just a tube - there isn't a one-way valve (at least on the 4.6).
Old May 8, 2012 | 10:28 AM
Bear Eats King...
Bear ****s Bone
Pcv valve is supposed to act as a one way valve... kinda
Old May 8, 2012 | 10:32 AM
Right - on other engines they have an actual valve in the tube. My older engines pcvalve need to be cleaned occasionally with carb cleaner to keep them free from gunk so they work. Whereas the 4.6 3V is just an open unobstructed tube.
Is it the same for the 5.0?
Old May 8, 2012 | 10:36 AM
Bear Eats King...
Bear ****s Bone
One side yes. But one side should have a pcv valve if I'm correct. Haven't looked to be honest. Just assumed they had one
Old May 8, 2012 | 01:44 PM
steve03gt's Avatar
If rings are not seated, there is more blow by, so more combustion air being sent through that tube. More Oil
Old May 8, 2012 | 02:59 PM
Bear Eats King...
Bear ****s Bone
True
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
lowblustang00
Sep 25, 2015 10:12 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
SterlingStunner
Sep 16, 2015 12:30 PM
