Oil pump gear failure
Probably 600+, it would make sense to replace them if you are thinking about making power of any kind IMO. Some will probably say it isn't needed but I would think it is cheap insurance since a new motor is about 8k.
Question: Why would increasing the HP output of the engine have any bearing on the oil pump? It’s as an engine driven accessory that would not see any greater stress as HP increases. I can see where an increase in engine RPM red line or heavier viscosity oil could potentially have an effect on its durability. What am I missing?
Thanks,
John
Thanks,
John
Thanks,
John
Thanks,
John
Once you raise the RPM's you start running the chance of the stock gear breaking. The oil pump gear turns off the crankshaft. The faster the engine spins, the faster the pump spins. The gears are not made of a strong metal.
Not quite the same thing comparing the oil pump drive gear to the internals of the engine.
We know the oil pump's gear is driven by the crank's rotation. That's four pulses per revolution as the cylinders fire. While it's not hydraulically locked, the oil pump does not want to turn easily when pushing oil through the engine. Adding more force to those impulses is what is putting the strain (torque) on the part. Even at the same RPM, you can beat the hell out of the gear by adding power.
Nick is correct...read on....
The load placed on the oil pump and its drivetrain will stay the same unless one or more of the following changes: the oil viscosity, the pumps bypass pressure (If equipped with a variable bypass valve), is operated beyond its maximum designed speed. The two caveats would be: 1) component flex or movement under greater stress loads of higher output engines such as the crank or block flexing potentially changing the gear lash as an example, and 2) harmonics at increased HP or RPM. Both are very real and documented failure modes in other engines.
Hypothetical: On a completely stock engine, say the pump requires 5 crank HP to pump 12gpm at 80psi to the engine at 7500 RPM. Increasing the engines total power output will not change the pumps load at all (unless one or more of the variables listed above are changed), it still requires 5hp because it is still pumping the same 12gpm at 80psi at 7500 RPM.
Following Brandon’s or El Coyotes line of thinking, adding hp to the engine would increase stress on the coolant pump, alternator, AC pump, etc. It won’t. They’re all “Slaves” or accessories powered BY the engine.
John
John
John
John
In your hypothetical, both engines would have the same load at that RPM. But there would be a significant difference in load rate when getting to that RPM. That's the added force I was referring to.
The other accessories also feel the increased force from the change in rate, but not as much. The belt drive helps reduce the damaging forces a lot.
John
John
Then why on the 03-04 Cobra's did the alternators fail religiously? My other argument has no basis but stick with me, the alternator on cars with root or centrifugal cars may burn up because of the strain from the blower, so then if you add a turbo to the car which shouldn't increase anything but HP do you then need to switch to better gears or leave them alone?
Rando
8/25/21 11:12 AM
