Oil consumption ?
Oil consumption ?
Ok so my 2013GT drinks about a quart of Motorcraft 5w20 every 3,000 miles not really excessive but more annoying then anything else. The car has 16,000 or so miles on it and runs fantastic with no motor "Tick" I'm thinking about moving up an oil grade say 5w30 Mobil 1 or even the 0w40 M1 grade to see if my oil use drops What do you all think should I give it a try?
As you say it's more of an annoyance than anything to really worry about. Sometimes a change in brands or going to 5w30 can help, but most of the time the change isn't major. What were your break in driving habits? I know this sounds a bit brutal, but I've learned from experience that a fresh engine gets the best ring seal if run hard through the gears for the first few hundred miles. I don't hammer too hard in 1 st. gear because there is too much gear reduction there to really load the rings against the cylinder walls. I run them hard from 2 nd. through 5th. up to at least 4,500-5,000 rpm. After the miles build up I increase the rpm until it's close to the limiter. I back off the throttle occasionally while doing this. This produces cylinder pressure which forces the rings hard against the walls. Backing off quickly creates vacuum which pulls oil past the rings momentarily thus cooling any hot spots that may exist. My '14 GT used about 1/2 a qt. in the first 3,500 miles. Now it dosen't use hardly any at all [ not enough to see on the dipstick ] between my 5,000 mile oil changes. I used this same procedure on a fresh rebuild on the small block Mopar in my '72 'Cuda with equally good results. I don't advocate being a maniac and bouncing the engine off the limiter every time you drive the car, but it is possible to baby them a bit too much as well.
Kestral , I am in the same boat. My 14 GT has 24k mi and it uses at least a qt ( using mobil 1) every 4k mi . I have to say I probably babied it too much during break in.
BackroadGT what M1 oil weight do you run?
Another option is the PCV system. You may be sucking some of that quart through the intake. Take the PCV hose off of the intake tube and check for oil. I have a Bob's oil separator and it catches a few tablespoons every 3k miles. It could also be a combination of both issues.
When I bought my 2014 GT I drove like I stole it from the beginning. No oil consumption at all. On the other hand it was delivered from another dealer 200 miles away, driven by a 70 year old man. Maybe he broke it in easy and I did the fun part! I have 13800 miles on it now after a year.
That's exactly what I was thinking.
I'm at 27,000KM... I typically go 10k between oil changes and will start to check the dipstick once a week once I hit that 8k on that oil change and my oil levels are in the normal range as well. haven't added a drop yet.
I use the 5w20 motorcraft oil from Ford.
As anyone with an oil separator [ at least a properly functioning one ] knows, some oil will come through the PCV system. Usually it's not enough to show on the dipstick. Of course the poorer the ring seal the more blow by and consequently the more oil you will have going through the PVC system.
