Oil Change at 8200...
i have 7/32s on front tires & 5/32s on rear tires, dealer recommend replacing the tires at the next oil change with they scheduled for 11,000 miles
i have done spirited driving, but defiantly not ***** to the wall burnouts, i honestly haven't done a burnout in this lol
what were the original specs for these tires, i have the std 18" rims with the pzeros
dam! tires start out with 10 to 11 32 on them as far as I know. Use them untill they get down to the wear bars between the treads. I think that is around 2 or 3/32. Don't buy tires from the dealership until you have done some price comparisons. As I am sure you know they usally over charge for things.
Every tire manufacturer on the planet will tell you that the minimum tread depth for a tire is when it reaches 2/32nd's (matter o' fact a bar is molded into the tire to let you know when that limit is reached).
Now depending on who you talk to, some people consider anything less than 4/32nd's to be unsafe since wet weather performance is effected.
You would think that tire manufacturers would be all over this since its a win for them - reduced mileaged warranties (by 10-20k) and sell more tires more often, even tires that have very well cared for.
I know Michelin's stance is that they do not reccomend replacing the tire till it reaches 2/32nd's of tread depth (Michlelin owns BFGoodrich BTW if you have BFG's on your car) and this is from the same company that doesn't reccomend rotating tires with more than 2/32nd's of tread depth differnce unless the lower tread depth tires are going to the front, they also reccomend replacing all 4 tires at the same time.
So if these guys aren't jumping on the 4/32nd's or less is unsafe then its probably not a big deal.
My advice would be to monitor your tire wear and when one set of tires on an axle reaches 2/32nds of tread depth (irregardless of the mileage you have recieved) then replace all four since the others wont be far behind. You dont need a tread depth gauge to tell when they get there, bars will appear or alternatively you can use lincoln's head on a penny as thats supposed to be 2/32nd's from his wig to the OD of the coin or just go buy a depth gauge.
FYI, most Ford dealers have "Quick Lanes" that specialize in oil changes, but are also tire stores. More importantly, most price match tire prices. I priced up my last tires on www.tirerack.com and www.discounttire.com, printed their prices, and the local Ford dealer's Quick Lane matched the best deal and handled my rebate paperwork (there was a $100 rebate being offered by the tire company at the time).
Someone else said what do you need a tread depth gauge for? You can watch you tread across each tire and adjust tire pressure accordingly so you have even tread wear. It will also help you see that your front tires on your 05-09 will wear out on the inside treads first if that problem does exist. I highly recommend a tread depth gauge no mater what car you drive..... fleebay FTW
DerekShiekhi
9/30/15 06:59 AM
