Negative effects of a heavy wheel?
Old 10/25/15 | 08:06 PM
FYVPTOH's Avatar
My 2014 GT came with the big silver 5-spokes. I bought replacements and dropped both the old and new rims on a scale to compare. I was surprised the stockers were only 26.0 pounds each. My replacements were Motegi MR126 18 X 8 wheels. Tire Rack advertised them at 18.9 pounds each but the scale read 19.9 which is still a total reduction of 24 pounds so I was happy.
Old 10/29/15 | 07:57 AM
bones302's Avatar
Originally Posted by trackpack13gt
how do I tune the car to use the aftermarket wheels? I think that is mostly the issue as when I hand calculated it I was getting 27mpg on the hwy.
I really like my supersnake rims and do not want to have to replace them with another set, any ideas?
there is also a device that recalibrates your speedometer in case you don't want to buy a tuner. I believe it is about $125. I was going to buy it when I switched from 19" to 20" wheels, but I figured out the MPH difference is only about 1-2%, so I left it alone.
Old 1/10/16 | 09:15 PM
trackpack13gt's Avatar
Right now the car is not being used for the winter. After hand calculating the mpg, the mpg is fine, it just needs a tuner to re calibrate it.
My issue is, should I sell the wheels and get lighter wheels?
I really like the supersnakes, 34lb 20x9 and 36lb 20x10. Looking at a boss302s 19x10 the weight is 34lb which seems pretty heavy for a performance derived wheel. I do not like pissing away money so if If the difference in performance is not noticeable i'd rather not. My main aim with the car is to have a very fast and sharp handling car.
Thoughts?
Old 1/11/16 | 04:15 PM
firstang001's Avatar
May be he is running a taller tire than stock which could down MPGs ????
Old 1/11/16 | 05:25 PM
Jazzman442's Avatar
The weight will not effect your MPG. It is the Rolling resistance and tire width. The wider the more resistance. Also if you changed the diameter to a smaller one will negatively effect MPG. Or maybe its just you pushing the pedal harder sine you have new tires. LOL
Old 1/12/16 | 05:41 AM
Bert's Avatar
Thoughts?
If you are going to spend the money for light wheels, you might as well get light wheels -- which means down around 20 pounds each. 18" Forgestars are in that area for about $350/each.
I didn't look back to see if you are tracking the car; but if you are only using it on the street, I very much doubt you will see any difference with the lighter wheels.
RCooke08GT
2/19/17 04:03 AM
Glenn
05-09 Exterior Modifications
13
10/26/15 09:29 AM
PonyMuscletang13
10/21/15 03:18 AM
10/2/15 02:00 PM
