Need quick answer-Will 2005-2010 17 inch Bullitt wheels fit 2011 GT?
They should fit although you should check front brake clearance since the 2011 GT front brakes are larger.
The other thing about the 17's is that you would need a very tall sidewall tire to make the diameter match the OEM 18's that come on the car and this will be detrimental to the handling. You would need a 255/50/17 tire to get the diameter right.
I do not think they will. I tried my 17" on my 2011 and the calipers rub against the ID of the wheel; the stock GT brake calipers actually rub more on the ID of my wheels than the Brembos !! My 17" are not bullits but have a slightly bigger ID than the bullits.
If you want, you can get the 05-10 caliper brackets + rotors ... your 17" bullits will fit then. The 2011 GT calipers & pads are the same as the 05-10
275/40's will be really short compared to stock.
What gear in your car?
appologies in advance for a minor hi-jack:
Will the "standard" 17" wheels fit on a 2010 GT or do I need something special?
I'm planning to get a set of 17" wheels with narrower/taller snow tires for the winter.
(yes it will be very painful to see "Ruby" covered with salt, but I have no choice)
With the 3.31's the short tire could help since it would be like going with a lower gear and a tall tire so the 275/40/17 drag radials may work well for you or even the wider 315/35/17's that are about the same height.
2010 GT has the same brakes as the 05-09 so the 17's will fit no problem.
I will be buying 295-45-17 brand new for 300.00 nice deal huh.
another thing to consider is whether the width of the DRs will work with the width of the wheels
the 17 inch stock wheels are 8 inches wide
what is the max width for DRs on these wheels?
maybe the 275s, but i doubt the 295s will work, i would think you would need a 10 inch wheel width for that
